Stability with Python Plugins
I know that the use of Python Plugins is beta.
But my experience is that after adding a python plugin as hardware, after a couple of hours, Domoticz stops working. When I restart the domoticz service, is works again for a couple of hours, but will stop again.
With Domoticz stopping, I mean that the domoticz web page gives off line, and (lua) scripts are not running. The raspberry pi is still accessible.
I am using jessie with python3 and python3-dev are the latest versions.
Any one with the same experience? Any suggestions how to solve this?
Raspberry Pi 2 with latest beta version
1x Aeon Labs USB Z-Stick S2
5x Fibaro Modules
5x Fibaro Modules
- EdwinK
- Domoticz version: BETA
Re: Stability with Python Plugins
I have the problem that when I add a python plugin (buienrader, circle360) after activating it, there is an error regarding devices. I have to completely remove the plugin and then restarting domoticz to fix it.
I didn't see any errors in the log. With a Python plugin created hardware but disabled(!), no problems.
5x Fibaro Modules
5x Fibaro Modules
It happens with any python plugin, even with the standard template plugin!!!
I just did a new installation with the latest stretch liet version on a Raspberry 2. Hopefully better result now
5x Fibaro Modules
5x Fibaro Modules
The Raspberry Pi with a new installation of Domoticz (latest beta) works fine. Two python plugins now running for 3 days without any problem.
5x Fibaro Modules
5x Fibaro Modules
I tested on 2 dev machine the same set of plugins,
first with Ubuntu 16.04 with latest apt-get upgrades and latest beta - sometimes crashes
second with Ubuntu 16.04 without apt-get upgrades and latest beta - without crash for 4 days
- Dnpwwo
@mrinner and @Noudje,
Sorry to hear you are still having issues. I have tried to reproduce them without success unfortunately. The stack traces which have been posted show errors very deep in Python which means I can't determine the cause.
On my main system I run 8 plugins continuously and the last time I restarted it had been running for 22 days without issue.
There is definitely some sensitivity to underlying software though. It has been know for some time that building from source for RPi gives a much more stable system than using the betas and its interesting that an Ubuntu without some patches is more stable than a patched one.
Running vanilla Stretch on an RPi3 built from source with nothing else on the Pi has been rock solid for me and has been for months.
Do you have anything else running on your machines?
@Dnpwwo:
On one RPi2B with Jessie, is Domoticz (only) running for 2 years without any problems. This is the one with problems with plugins
An other RPi2B with Stretch and a complete new install of the latest beta is running very good. 3 Plugins are running without any problem
5x Fibaro Modules
5x Fibaro Modules
- EdwinK
For me, this is still a problem. The Pi is only being used for Domoticz. The only thing I changed is that after booting everything else runs from an external drive. I do not really dare to compile this my self, as I'm not really into this. I rather install and forget. Besides, the instructions scare me a bit. I really hope that there will be a solution soon.
I have the same issue.
Domoticz crash just after I enable plugin
see catchsegv log below
https://gist.github.com/lrybak/f7be098b ... 989895dd9b
I'm running RPI3 on stretch lite.
There are no many tools installed on that Pi, domoticz, monit, mosquitto and few really small tools
I have running domoticz on ubuntu server on vmware machine. Plugin works rock stable there
HW: HP dc7900 USD running ESXi, RaspberryPi (few of it), AEON S2 USB stick, Fibaro modules (Dimmers, switches), 1-wire (DS18B20, DS2423), DSC Alarm with Envisalink ethernet module, MySensors, RFLink
- Dnpwwo
Pushed a fix yesterday where plugins could crash when being stopped (or restarted) if they updated a device in onDisconnect or onStop.
Don't think it will help with general stability but every fixed issue get us closer to where we want to be !
I found out that most of the problems come from plugins using connections!
I created a simple plugin based on the HTTP.py example. In the example in onStart, you find:
I removed the last line and placed that in the onCommand and onHeartbeat procedures. It is running now for days without any problem.
self.httpConn = Domoticz.Connection(Name="HTTP Test", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.httpConn.Connect()
5x Fibaro Modules
5x Fibaro Modules
Yes possible... I have got here (using Domoticz.Connection) as sample:Noudje wrote: ↑Thursday 21 December 2017 22:04 I found out that most of the problems come from plugins using connections!
I removed the last line and placed that in the onCommand and onHeartbeat procedures. It is running now for days without any problem.Code: Select all
self.httpConn = Domoticz.Connection(Name="HTTP Test", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"]) self.httpConn.Connect()
'CConnection_send' failed 'TypeError':''dict' does not support the buffer interface'.
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
That matches with a problem I encountered this week.
A plugin based on the plugin template, doing “almost nothing” has been running without problem for many months.
This week I started with a plugin using Http connections and suddenly Domticz crashes frequently.
Since I am just starting with those plug-ins I assumed I created the problem myself, So maybe I did not!
Thanks for the hint.
- Dnpwwo
@micha_pr,
You are getting an error returned, not a crash. If you post some of your code I can have a look to see if the Send function can be improved.
No, it is an additional part of the crash. Maybe not everytime it will appear in the log,
Please look here, there is the plugin and more info:
https://www.domoticz.com/forum/viewtopi ... 65&t=20625
Michael Pruefer
- Dnpwwo
@micha_pr,
What version of the beta are you running? I had a look at the link you specified and the error messageis very out of date, the parameters (and error) are now
can you update to the latest and see if the problem still exists?
failed to parse parameters, Message or Message,Verb,URL,Headers,Delay expected.
failed to parse parameters, Message or Message, Delay expected.
I was going back to stable version, because of problems with plugin in latest Beta (3.8795).
Original errors came from 3.8794. See also here:
https://github.com/domoticz/domoticz/issues/1891
But release version didn't help. I will update to latest version again and tell you.
Michael Pruefer
