The script (is just a small edit on the original idealarmhelpers just the devices are remarked or changed)
Edit this file suit your needs
Place this file in the dzVents scripts folder using the name ideAlarmConfig.lua
See https://github.com/allan-gam/ideAlarm/wiki/configuration
After editing, always verify that it's valid LUA at http://codepad.org/ (Mark your paste as "Private"!!!)
local _C = {}
-- ideAlarm Custom helper functions. These functions will be called if they exist.
_C.helpers = {
alarmZoneNormal = function(domoticz, alarmZone)
-- Normal is good isn't it? We don't have to do anything here.. We could but..
end,
alarmZoneArming = function(domoticz, alarmZone)
-- You can define something to happen here.
-- This function will be called when arming and waiting for the exit delay.
-- If the exit delay is 0 seconds, this function will not be called.
end,
alarmZoneTripped = function(domoticz, alarmZone)
-- A sensor has been tripped but there is still no alert
-- We should inform whoever tripped the sensor so he/she can disarm the alarm
-- before a timeout occurs and we get an alert
-- In this example we turn on the kitchen lights if the zones name
-- is 'My Home' but we could also let Domoticz speak a message or something.
--local trippedSensors = alarmZone.trippedSensors(domoticz, 1) -- Can be used if we need to.
if alarmZone.name == 'Thuis' then
-- Let's do something here
domoticz.devices('DIM-Keuken').dimTo(100)
domoticz.devices('DIM-PlafondWK').dimTo(100)
end,
alarmZoneError = function(domoticz, alarmZone)
-- An error occurred for an alarm zone. Maybe a door was open when we tried to
-- arm the zone. Anyway we should do something about it.
domoticz.notify('Alarm Zone Error!',
'There was an error for the alarm zone ' .. alarmZone.name,
domoticz.PRIORITY_HIGH)
end,
alarmZoneArmingWithTrippedSensors = function(domoticz, alarmZone, armingMode)
-- Tripped sensors have been detected when arming. If canArmWithTrippedSensors has been set
-- to true in the configuration file for the zone, arming will proceed,
-- if not, then the alarmZoneError function will be called subsequently and arming will not occur.
local msg = ''
local isArming = true
local trippedSensors = alarmZone.trippedSensors(domoticz, 0, armingMode, isArming)
for _, sensor in ipairs(trippedSensors) do
if msg ~= '' then msg = msg..' and ' end
msg = msg..sensor.name
if msg ~= '' then
msg = 'Open sections in '..alarmZone.name..'. '..msg
domoticz.notify('Open sections when arming',
msg .. alarmZone.name,
end,
alarmZoneAlert = function(domoticz, alarmZone, testMode)
local msg = 'Intrusion detected in zone '..alarmZone.name..'. '
local oneMinute = 1
for _, sensor in ipairs(alarmZone.trippedSensors(domoticz, oneMinute)) do
msg = msg..sensor.name..' tripped @ '..sensor.lastUpdate.raw..'. '
if not testMode then
domoticz.notify('Alarm Zone Alert!',
msg, domoticz.PRIORITY_HIGH)
domoticz.log('(TESTMODE IS ACTIVE) '..msg, domoticz.LOG_INFO)
end,
alarmArmingModeChanged = function(domoticz, alarmZone)
-- The arming mode for a zone has changed. We might want to be informed about that.
local zoneName = alarmZone.name
local armingMode = alarmZone.armingMode(domoticz)
domoticz.notify('Arming mode change',
'The new arming mode for ' .. zoneName .. ' is ' .. armingMode,
domoticz.PRIORITY_LOW)
-- Buy a Fibaro Wall Plug 2 and configure it to display red when off, green when on
-- You can then use it as in alarm arming mode indicator!
if armingMode == domoticz.SECURITY_DISARMED then
-- domoticz.devices('Alarm Status Indicator').switchOff() -- Green light on
--else
-- domoticz.devices('Alarm Status Indicator').switchOn() -- Red light on
end,
alarmNagOpenSensors = function(domoticz, alarmZone, nagSensors, lastValue)
if #nagSensors == 0 and lastValue > 0 then
domoticz.log('The previously reported sections are now closed! Good work!', domoticz.LOG_INFO)
elseif #nagSensors > 0 then
local msg = ''
for _, sensor in ipairs(nagSensors) do
msg = 'Open sections in zone: '..alarmZone.name..'. '..msg
domoticz.log(msg, domoticz.LOG_INFO)
end,
alarmOpenSensorsAllZones = function(domoticz, alarmZones)
-- Toggle the big red lamp if there are any open sensors in 'My House'
for _, alarmZone in ipairs(alarmZones) do
--if (alarmZone.openSensorCount > 0) then
-- domoticz.devices('Big Red Lamp').switchOn()
--elseif (alarmZone.openSensorCount == 0) then
-- domoticz.devices('Big Red Lamp').switchOff()
--end
end,
return _C
test script and output
active = true,
devices = {
'0-Test'
if (device.name == '0-Test' and device.state == 'On') then
domoticz.devices('DIM-Keuken').dimTo(100) end
2017-12-09 09:00:17.675 User: xxxxxxx initiated a switch command (741/0-Test/On)
2017-12-09 09:00:17.684 (Dummy) Light/Switch (0-Test)
2017-12-09 09:00:17.792 dzVents: Info: Handling events for: "0-Test", value: "On"
2017-12-09 09:00:17.792 dzVents: Info: ------ Start internal script: 0-Test: Device: "0-Test (Dummy)", Index: 741
2017-12-09 09:00:17.793 dzVents: Info: ------ Finished 0-Test
2017-12-09 09:00:17.824 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 50 (0x32)
2017-12-09 09:00:17.830 (Z-wave) Light/Switch (DIM-Keuken)
idealarmdebug
2017-12-09 09:03:25.005 dzVents: Info: Handling events for: "Achterdeur motion", value: "Closed"
2017-12-09 09:03:25.005 dzVents: Info: ideAlarm V2.1.1: ------ Start external script: ideAlarm.lua: Device: "Achterdeur motion (Z-wave)", Index: 724
2017-12-09 09:03:25.006 dzVents: Debug: ideAlarm V2.1.1: Triggered by device: Achterdeur motion, device state is: Closed
2017-12-09 09:03:25.006 dzVents: Info: ideAlarm V2.1.1: triggerType sensor
2017-12-09 09:03:25.007 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Voordeur motion: Switch device adapter
2017-12-09 09:03:25.007 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Voordeur motion: Switch device adapter
2017-12-09 09:03:25.008 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Voordeur Arming Mode: Text device
2017-12-09 09:03:25.008 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Voordeur Arming Mode: Text device
2017-12-09 09:03:25.009 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.010 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.010 dzVents: Info: ideAlarm V2.1.1: ------ Finished ideAlarm.lua
2017-12-09 09:03:25.357 (Dummy) General/Text (Achterdeur Status)
2017-12-09 09:03:25.574 dzVents: Info: Handling events for: "Achterdeur Status", value: "Timed out"
2017-12-09 09:03:25.575 dzVents: Info: ideAlarm V2.1.1: ------ Start external script: ideAlarm.lua: Device: "Achterdeur Status (Dummy)", Index: 736
2017-12-09 09:03:25.575 dzVents: Debug: ideAlarm V2.1.1: Triggered by device: Achterdeur Status, device state is: Timed out
2017-12-09 09:03:25.575 dzVents: Info: ideAlarm V2.1.1: triggerType status
2017-12-09 09:03:25.575 dzVents: Debug: ideAlarm V2.1.1: Deal with alarm status changes for zone Achterdeur
2017-12-09 09:03:25.577 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.577 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.577 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: 736|0|Alert TRIGGER
2017-12-09 09:03:25.577 dzVents: Info: ideAlarm V2.1.1: Achterdeur new status: Alert immediately
2017-12-09 09:03:25.578 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for DIM-PlafondWK: Switch device adapter
2017-12-09 09:03:25.578 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for DIM-PlafondWK: Switch device adapter
2017-12-09 09:03:25.579 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for DIM-Keuken: Switch device adapter
2017-12-09 09:03:25.580 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for DIM-Keuken: Switch device adapter
2017-12-09 09:03:25.580 dzVents: Info: ideAlarm V2.1.1: ------ Finished ideAlarm.lua
2017-12-09 09:03:25.715 dzVents: Info: Handling events for: "Achterdeur Status", value: "Alert"
2017-12-09 09:03:25.716 dzVents: Info: ideAlarm V2.1.1: ------ Start external script: ideAlarm.lua: Device: "Achterdeur Status (Dummy)", Index: 736
2017-12-09 09:03:25.716 dzVents: Debug: ideAlarm V2.1.1: Triggered by device: Achterdeur Status, device state is: Alert
2017-12-09 09:03:25.716 dzVents: Info: ideAlarm V2.1.1: triggerType status
2017-12-09 09:03:25.717 dzVents: Debug: ideAlarm V2.1.1: Deal with alarm status changes for zone Achterdeur
2017-12-09 09:03:25.718 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.718 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Achterdeur Arming Mode: Text device
2017-12-09 09:03:25.719 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for Achterdeur motion: Switch device adapter
2017-12-09 09:03:25.719 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for Achterdeur motion: Switch device adapter
2017-12-09 09:03:25.719 dzVents: !Info: ideAlarm V2.1.1: Turning on noise for zone Achterdeur
2017-12-09 09:03:25.720 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for DIM-PlafondWK: Switch device adapter
2017-12-09 09:03:25.720 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for DIM-PlafondWK: Switch device adapter
2017-12-09 09:03:25.720 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: On
2017-12-09 09:03:25.721 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: On NOTRIGGER
2017-12-09 09:03:25.721 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off
2017-12-09 09:03:25.721 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off AFTER 300 SECONDS
2017-12-09 09:03:25.721 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off AFTER 300 SECONDS NOTRIGGER
2017-12-09 09:03:25.722 dzVents: Debug: ideAlarm V2.1.1: Device-adapter found for DIM-Keuken: Switch device adapter
2017-12-09 09:03:25.722 dzVents: Debug: ideAlarm V2.1.1: Processing device-adapter for DIM-Keuken: Switch device adapter
2017-12-09 09:03:25.722 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: On
2017-12-09 09:03:25.722 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: On NOTRIGGER
2017-12-09 09:03:25.722 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off
2017-12-09 09:03:25.723 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off AFTER 300 SECONDS
2017-12-09 09:03:25.723 dzVents: Debug: ideAlarm V2.1.1: Constructed timed-command: Off AFTER 300 SECONDS NOTRIGGER
2017-12-09 09:03:25.725 dzVents: Info: ideAlarm V2.1.1: ------ Finished ideAlarm.lua
