- Domoticz version: 4.10538
Re: Dashticz iphone
Yes it does work in the safari browser on iPhone.
Do you have a specific confirmation for your iPhone?
(I do not)
(I do not)
- Domoticz version: 2021.1
Re: Dashticz iphone
It gives a blank screen on my iphone screen,
Must i do do something special?
my config only has:
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.3.119:80';
var _USE_AUTO_POSITIONING = true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
changing use_favorites or use_auto_positioning does not help.
I also have a more filled in CONFIG.js, same effect.
certain items are not displayed.
I can find no difference between the items displayed and the items that are not there.
It is not like only the first 50 are displayed, the IDX's that are missing are random.
- htilburgs
This config cannot work. Var _use_favorites=false, nothing is displayed.
This is also the “old style” of configuration.
The current version of Dashticz uses a new kind if config.
Maybe you’ve to install Dashticz again in another directory (see wiki) and copy the sample config to CONFIG.js and edit your settings for Domoticz.
See current Wiki for hands-on.
Hardware:
Re: Dashticz iphone
Just retried today (running beta of end of last week), scaling is not optimal, but it is displaying everything I have in other browsers.
Can you try with a default config (using favorites and auto-positioning?
Is it possible to hide the title of a selector switch?
- htilburgs
[‘title’]=‘’
Hardware:
Wow, quick response, thnx.
I've got an additional wish, this default solution does keep space reserved for the title, I would also like to remove that
Re: Dashticz iphone
I use the default config,
But does this only work in the beta version?
Thanks for your reply,htilburgs wrote: ↑Monday 04 December 2017 20:52 This config cannot work. Var _use_favorites=false, nothing is displayed.
FYI also with _use_favorites=false it should work. But I also tried it with true.
I do have over 50 devices that are shown, but not all are shown. I am missing a lot.
New config, empty config, old working config, they all miss a large number of devices.
still trying..........................
- Domoticz version: 3.7067
No, _use_favorites should not work (in the beta), this is the old way
This config works over here, but, honestly, I dont have that many devices
Maybe I can take a look via Teamviewer?
var config = {}
config['domoticz_ip'] = 'IP:PORT';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['standby_after'] = 1;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '0';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'YOUR API';
config['gm_zoomlevel'] = '0';
config['gm_latitude'] = '0';
config['gm_longitude'] = '0';
config['speak_lang'] = 'en-US';
config['wu_api'] = 'YOUR WU API';
config['wu_city'] = 'Eindhoven';
config['wu_name'] = 'Eindhoven';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = '0';
config['switch_horizon'] = '0';
config['sonarr_url'] = '';
config['sonarr_apikey'] = '';
config['sonarr_maxitems'] = '';
config['garbage_company'] = 'deafvalapp';
config['garbage_icalurl'] = '';
config['garbage_zipcode'] = '5692VG';
config['garbage_street'] = '';
config['garbage_housenumber'] = '29';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '5';
config['garbage_hideicon'] = '0';
config['no_rgb'] = '0';
config['auto_positioning'] = '0';
config['use_favorites'] = '0';
config['last_update'] = 1;
config['hide_topbar'] = '0';
config['edit_mode'] = '0';
config['hide_seconds'] = '0';
config['hide_seconds_stationclock'] = '0';
config['use_fahrenheit'] = '0';
config['use_beaufort'] = '0';
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = '0';
Is it possible to show the log of a dummy switch? I use several dummy switches to create a kind of alarm system. The dummy switches are switching by motion sensors and if a special number of dummy switches are on, another dummy switch will be switched on. I would like to see the log of that so I could see how often it happened during night.
Thx
Thx
Yes it does. I've also had trouble first time running it on iphone.
Make sure you set:
config['auto_positioning'] = 0;
Thanks,
I will try that.
I will try that.
Thanks,
I Did try that but it doesnt help.
Could you share your config?
I'm on latest beta. Arrows up and down for blinds doesn't work. Just me?
- Domoticz version: Beta Ch
Where does dashticz save its configuration and other files (other that main folder) ? I would like to get them all removed for fresh installation ...
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Will check the arrows for blinds.
It only uses your own config.js ... (in custom-folder).
But if you see strangs things, this could happen because of browser-caching..
- EdwinK
- Domoticz version: BETA
CONFIG.js ?
I'm new to Dashticz and Domoticz and I think I'm having the same problem as Frankdutch on page 149. It looks like Dashticz looses it's connection to Domoticz as soon as I start using the config.js. When I start Dashticz with the config.js file commented I can see everyhing that's in my favourites within Domoticz. When I uncomment it it's impossible to see any buttons. Does anyone know how this got solved? I did use authentication for my Domoticz once but not anymore.
