Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
I have an issue tonight : GH says it can't communicate with my domotic.
Am I the only one ?
access to my domoticz from outisde is working fine (with ssl certificat error)
Flavien
Am I the only one ?
Flavien
Am I the only one ?
Flavien
Am I the only one ?
Flavien
hi - can you unlink, then relink to Controlicz in the Home app?
That worked thank you very much.
I had the login poping up twice, but it worked at the end.
I've lost the custum name, I've put in Google home config; but I shoud change those name on the domoticzdescription field anyway.
Thanks a lot
Flavien
good to know, glad it worked
bien sûr!
Hi Madgeni,
Could I get invited as well? My email address is [email protected]
Looking forward to testing it.
done
Hello (Bonjour),
Can i try Controlicz for my GH ?
I send you my address in a PM ?
Thank (Merci)
Thank (Merci)
sure, send me your email address and i'll add you
I'd like to join the GH-beta too, but as a new user am not able to send you a PM. Would you be able to send me a PM so I can reply?
Well, thank you for adding me.
But I'm stuck at first step When I click "start testing" I only see "Actions on google" and nothing about Controlicz username/passwd.
BTW I'm having this issue when changing language "App cannot be tested because it does not yet support 'fr-FR' as a locale"
ok - so once you've enabled testing - switch over to your Home app/Google Assistant, then you should find the app - you can launch it, then it will prompt you to put in your Controlicz username/password
Hey Madgeni,
I would like to test controlicz with domoticz and google home. My email on controlicz is: [email protected]
Hi there -
Email addresses and domains must be associated with an active Google Account or Google Apps account
Raspberry Zero PI 3 B
Evohome wifi Evohome HGI80 Evohome Web
4x Rfxcom
Google AIY
Z-Wave
OpenPlotter
4x Rfxcom
Google AIY
Z-Wave
OpenPlotter
