The communication protocol with the Cube has been reverse engineered, and a good description can be found at https://github.com/Bouni/max-cube-protocol. This is the basis for the scripts and plug-ins that exist for various home automation systems. I can't seem to find any reference to the boiler switch after a quick scan, but maybe others have time to search better. If it's not documented here, the chance that we can control it is low.oasisnl wrote:As I look at the manual with this box it responses to the max cube commands when one of the valves/thermostats has a heating request. I'm not sure if the device will be added in domoticz using the provided scripts. But since domoticz is controlling the thermostats and valves and then the cube sends an signal to the boiler contoller there may be no need to see the controller in domoticz. Downsite is that you won't be able to check the status of the boiler within domoticz. Overall I guess it will be able to control your boiler, maybe not directly from domoticz but through the values of the thermostats and valves which are controlled by domoticz.
This is just my opinion, also myself just starting with max! and actually still looking for a good boiler controller solution.
I personally check the percentage of my valves with a Domoticz script, and use a Z-wave switch to control my boiler if there is heat demand.
