OpenWebNet developing..?
spugna85
Re: OpenWebNet developing..?
It is the state of the mobile network if you have a sim in your 3486.
if you have problems with the GPRS network, then this alarm is generated.
bmath
hi,
Fisrt of all congrats for your awesome work on this plugin.
i add my gateway yesterday on the beta of domotics. my ligts and blinds are working well and are recognized by the system.
My questions are :
1/
in my log, i have :
2017-04-27 11:31:49.372 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 11:31:49.442 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 11:31:49.892 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 11:31:49.972 Error: COpenWebNetTCP: Who=4 frame error
how to fix this?
2/
how to get informations about elec by the gateway F455?
2/
how to get informations about temperatur by the gateway F455?
My questions are :
1/
in my log, i have :
how to fix this?
2/
2/
- emme
- Domoticz version: latest
Ciao,
did you add the domoticz IP in the whitelist of your F455? (under Administration/network as far as I remember)
if not... you would not be able to get devices
Devices are created as soon as they send a notification to the server (you will see them in the log) and if the automatic acceptance of new devices (under settings) is enable in domoticz
it could takes a day to complete the device presence
ciao
M
ciao
M
"We always done this way"
bmath
The domoticz is in the whitelist otherwise i couln't control lignht and blind.
see below more log :
2017-04-27 12:16:43.613 Hardware Monitor: Fetching data (System sensors)
2017-04-27 12:16:49.362 COpenWebNetTCP: received=*4*202*1## : NORMAL FRAME - who=Temperature control - what=thermal Protection - where=area 1
2017-04-27 12:16:49.362 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 12:16:49.402 COpenWebNetTCP: received=*#4*1*0*0206## : MEASURE FRAME
2017-04-27 12:16:49.402 (Myhome) Temp (TEMPERATURE 1)
2017-04-27 12:16:49.432 COpenWebNetTCP: received=*4*303*1## : NORMAL FRAME - who=Temperature control - what=OFF(Generic) - where=area 1
2017-04-27 12:16:49.432 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 12:16:49.882 COpenWebNetTCP: received=*4*202*2## : NORMAL FRAME - who=Temperature control - what=thermal Protection - where=area 2
2017-04-27 12:16:49.882 Error: COpenWebNetTCP: Who=4 frame error!
2017-04-27 12:16:49.922 COpenWebNetTCP: received=*#4*2*0*0210## : MEASURE FRAME
2017-04-27 12:16:49.922 (Myhome) Temp (TEMPERATURE 2)
2017-04-27 12:16:49.962 COpenWebNetTCP: received=*4*303*2## : NORMAL FRAME - who=Temperature control - what=OFF(Generic) - where=area 2
2017-04-27 12:16:49.962 Error: COpenWebNetTCP: Who=4 frame error!-
bmath
I apologie
it's working after accept "allow new devices for the next 5 minutes"
bmath
by the way, do you know how add a module like a F430 to monitor Electricity in Domoticz?
spugna85
F430 is used for thermoregulation.
F520, F521, F523 are used to monitor power consumption but are not yet supported.
well i started playing around a bit... but i am kinda confused from what i get in my log. What is what 19?
Do the interfaces work correctly?
2017-05-09 13:46:08.326 COpenWebNetTCP: received=*1*1*64#4#02## : NORMAL FRAME - who=Lighting - what=Turn on - where=room 6, point of light 4
2017-05-09 13:46:08.326 COpenWebNetTCP: received=*1*19*26#4#06## : NORMAL FRAME - who=Lighting - what=Unknown what : 19 - where=room 2, point of light 6
2017-05-09 13:46:08.326 COpenWebNetTCP: received=*#1001*29#4#05*11*111111111111111111111111## : MEASURE FRAME
2017-05-09 13:46:08.326 Error: COpenWebNetTCP: Who=1001 not yet supported!
2017-05-09 13:46:08.326 COpenWebNetTCP: received=*1*19*29#4#05## : NORMAL FRAME - who=Lighting - what=Unknown what : 19 - where=room 2, point of light 9
2017-05-09 13:46:08.326 COpenWebNetTCP: received=*#1001*26#4#06*11*111111111111111111111111## : MEASURE FRAME
spugna85
I think interface management was done by steplebr61. Then other changes have been made and I can not tell if it still works.shubell wrote:well i started playing around a bit... but i am kinda confused from what i get in my log. What is what 19?
Unfortunately, I can not test this functionality in my system. I suggest you try to contact who did this.
Hello together,
I have an Bticino System installed in my House.
The system included steering of the blindes and Audio System.
Steering of the blindes works perfect with domoticz but i can not Switch on or off the Bticino Audio system.
The Audio System is also controlled by Bus and openweb protocol.
Has anyone an idea to implement the Audio system in domoticz?
Martin
Gesendet von meinem MHA-L29 mit Tapatalk
Martin
Hi dimk, i think i'll be able but i don't have the hw to test it. You have to test it for me.
Hello
I have the Hardware, how can i help you?
Look for me on skype so we can talk
Sorry, i still can't send private messages. My nick on skype is the same olix81 (Col Hannibal Smith as avatar pcture)
fmal
Reading status of F430
Is it possible to read the F430/2 status (actuator for heating pumps) from domoticz and report the amount of time of activation for each module?
spugna85
I think you can do it easily, but you can not monitor the status of the f430 relay.
you need to intercept the status of the temperature probe, in fact when this changes, a specific openwebnet message is generated.
This could be interpreted as a new contact type device, but at the moment I do not have the time to do this ...
woody4165
I see that some command are not stil supported, even I see it in the log telling that are unsupported.
Is it possible to make a trigger on the log when this unsupported commands are shown so that I can make in any case an action?
spugna85
Re: Reading status of F430
Hi fmal, in the last beta version is available the monitoring of the F430 relays (actuator and valves).fmal wrote: Friday 06 October 2017 17:30 Is it possible to read the F430/2 status (actuator for heating pumps) from domoticz and report the amount of time of activation for each module?
The first time the actuator changes status, Domoticz inserts a "contact" type device.
Then you can see the status changes and the graph through the device logs ..
I hope this helps
fmal
Hey, it sounds great! Just downloaded the beta release and in fact it sees the actuator. But it is a two way actuator (F430/2) and I see only one switch. Each F430/2 manages two heating zones... how can I seew two switches?
Thank you for your great job!
Edit: after a while I have 3 objects:
MyHome_OTC 01F80000
MyHome_OTC 01F80002
MyHome_OTC 01F80001
I suppose that one of f430 switches all the pumps, and the other one manages the two zones (I can see the switch changing status in domotics).
I need to study it !! TY
MyHome_OTC 01F80000
MyHome_OTC 01F80002
MyHome_OTC 01F80001
fmal
It works perfectly! Great Job!!!
Another question: I have just installed MSH1 as new gateway, but I'm not sure I can use it to reach my bus. The Open password must be setted on MSH1 as alphanumeric but domoticz does not allows letters inside the password so I cannot use it as gw (I'm still using the unsupported touch 3.5)
TY for any advice
TY for any advice
