Xiaomi Gateway - Setting light color
misfit
Post by misfit »
I can dim the light with 'level (%)' but how to set RGB color? (Tried to put hex value in 'number' block but seems thats not the right way :)
DAVIZINHO
Re: Xiaomi Gateway - Setting light color
Post by DAVIZINHO »
i make it in dzvents scripts with this code:
 local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.1.4:8084/json.htm?type=command&param=setcolbrightnessvalue&idx=20&hue=236&brightness=1&iswhite=false"'
os.execute(sceneCmd)
change the ip and port to conect
change the idx (20 in my case)
change de colour (236 in my case)
and change the brightness (1 in my case)
misfit
Post by misfit »
I see this skeleton when creating a new dzvents script:
		devices = {
			'myDevice'
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
How to utilize your code, if lets say i want to set the color when a user variable changing? (I set the variable with a timed blocky event.)
Schorschi
Post by Schorschi »
i also try to set the colour of the Xiaomi Gateway with a LUA Script.
But i can only set the brightness with:
commandArray['Xiaomi RGB Gateway']='Set Level:100'
I also tried to set RGB values with Set Level but it does not work.
I don't know which command is needed to set this configuration.
Can some one explain me how to find out this information? Maybe also basicaly how to do it on other devices?
Logfile only shows Set Level if i change the colour in the web interface.
thx.
Schorschi
Post by Schorschi »
i am again.
I also tried this in my lua script:
        	local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.178.55:9898/json.htm?type=command&param=setcolbrightnessvalue&idx=1&hue=236&brightness=100&iswhite=false"'
			exec_success = os.execute(sceneCmd)
But the LED light don't switch on and the variable exec_success is nul.
How can i test this os command separately?
If i try it on my console and get no error.
Domosticz is running on an raspi 1. And connected to Xiaomi Gateway V2.
Any ideas?
Thx.
DAVIZINHO
Post by DAVIZINHO »
y use this comand in a dzvents script and works perfect
Schorschi
Post by Schorschi »
i get running this command in my lua device script.
But sometimes i get an error => scirpt run for more then 10 seconds ....
Is my raspi 1 to slow???
Some one same experiance? Maybe any ideas?
Thx.
QSKONE
Post by QSKONE »
Can you add some printscreens = examples how they work?
Schorschi
Post by Schorschi »
here an example of my lua script.
Addapt your ip and port of your domoticz device
Red   =  	0xFF0000 	--(255,0,0)
GatewayColour = Red
		local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.10.1:8080/json.htm?type=command&param=setcolbrightnessvalue&idx=1&hex=0x'..string.format("%x", GatewayColour)..'&brightness=100&iswhite=false"'
QSKONE
Post by QSKONE »
Thanks mate, but i am absolute beginner , try to write first script ever .Can you add complete from A to Z script?
hekm77
Post by hekm77 »
QSKONE wrote: Tuesday 13 February 2018 16:56
If interesting, You can try.
You must create two Dummy Switch, type - Dimmer: miGateway Hue and miGateway Bri
In the script , enter your username, password, ip and port domoticz.
dzVents 2.4.x
        devices = {
            'miGateway Hue',
            'miGateway Bri'
    logging = {
        level = domoticz.LOG_ERROR
    execute = function(dz, item)
         local Gateway   = dz.devices('Xiaomi Gateway RGB')
         local HueDevice = dz.devices('miGateway Hue')
         local BriDevice = dz.devices('miGateway Bri')
         url = "http://username:password@ip_ddomoticz:port_domoticz/json.htm?type=command&dparam=setcolbrightnessvalue&"
        if HueValue == nil then HueValue = 0 end
        if BriValue == nil then BriValue = 0 end
 function GatewayOn()
    SetScene = 'curl -s '..'"'..url..'idx="'..Gateway.idx..'"&hue="'..HueValue..'"&brightness="'..BriValue..'"&iswhite=false" &'
    dz.utils.osExecute('('..SetScene..' > /dev/null)&')
         HueValue  = dz.utils.round(HueDevice.level * 3.59),0
         BriValue  = BriDevice.level
        if (item.name == 'miGateway Hue') then
               if (item.state ~= 'Off') then
                      if (BriDevice.state == 'Off') then
                          BriValue = BriDevice.lastLevel
                          GatewayOn()
                          BriDevice.dimTo(BriDevice.lastLevel).silent()
                          item.dimTo(item.level).silent()
                          GatewayOn()
                   Gateway.switchOff().checkFirst().silent()
                   BriDevice.switchOff().checkFirst().silent()
        if (item.name == 'miGateway Bri') then
                      if (HueDevice.state == 'Off') then
                          HueValue = dz.utils.round(HueDevice.lastLevel * 3.59),0
                          GatewayOn()
                          HueDevice.dimTo(HueDevice.lastLevel).silent()
                          GatewayOn()
                   HueDevice.switchOff().checkFirst().silent()
QSKONE
Post by QSKONE »
hekm77 many thanks. Domoticz Xiaomi Wiki must including your script because it's very helpful.
MarnixO
Domoticz version: V4.10199
Post by MarnixO »
On a Synology i got an error :
2018-06-04 02:37:37.094 Error: dzVents: Error: ...icz/var/scripts/dzVents/generated_scripts/Xiaomi RGB.lua:26: attempt to index field 'utils' (a nil value)
Schorschi
Post by Schorschi »
to set color for the xiaomi gateway is not working in the last domoticz beta and current gateway fw.
I try it with my old script but can't change the color. The gateway switch always to the last manually selected color.
		-- Gateway Colour
	       commandArray['Xiaomi_RGB_Gateway']='Set Level:'..tostring(GatewayBrightness) -- set brightness LED light from Gateway
		-- change colour of gateway
		local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.178.62:8083/json.htm?
any idea?
