Monit for mosquitto
costo
Domoticz version: 2025.1
Monit for mosquitto
Post by costo »
Followed the wiki and installed monit for domoticz, that works perfect.
I have this part in /etc/monit/monitrc for domoticz
  check process domoticz with pidfile /var/run/domoticz.pid
  start program = "/etc/init.d/domoticz.sh start"
  stop  program = "/etc/init.d/domoticz.sh stop"
  if failed
     url http://127.0.0.1:8080/json.htm?type=command&param=getversion
         and content = '"status" : "OK"'
     for 2 cycles
     then restart
  if 5 restarts within 5 cycles then exec "/sbin/reboot"
Now I like to monitor mosquitto also , so i added this at the end of /etc/monit/monitrc
  check process mosquitto with pidfile /var/run/mosquitto.pid
  start program = "/etc/init.d/mosquitto start"
  stop  program = "/etc/init.d/mosquitto stop"
I got a new Monit mosquitto page, but it does not work as supposed. After initialising it says: execution failed.
What can I do to make this work ?
Note: I run jessie on a raspberryPi 2b
SweetPants
Re: Monit for mosquitto
Post by SweetPants »
mosquitto does not use a PID, look in /var/run
costo
Post by costo »
Thanks for the reply
SweetPants wrote: Sunday 03 December 2017 17:44 mosquitto does not use a PID, look in /var/run
I see a /var/run/mosquitto.pid file , just as domoticz has one, both 6 Bytes in size. In mosquitto.pid there is a number which is different all the time.
The only difference is in the permissions, domoticz.pid = --- and mosquitto.pid = r--
After removing the line "check process mosquitto with pidfile /var/run/mosquitto.pid" from monitrc, monit does no longer have a page named mosquitto.
This is no solution for monitoring mosquitto
tonbor
Post by tonbor »
here is the answer, for people to help https://rouwette.com/install-monit/
Kedi
Post by Kedi »
Mine is:
check process mosquitto matching "mosquitto"
     start program = "/bin/systemctl start mosquitto"
     stop program = "/bin/systemctl stop mosquitto"
     if 4 restarts within 5 cycles then alert
     if 5 restarts within 5 cycles then timeout
Users browsing this forum: jvdz and 1 guest
