Python plugin: Xiaomi Mi Robot Vacuum Topic is solved
Re: Python plugin: Xiaomi Mi Robot Vacuum
@DAVIZINHO
Try delete __pycache__ in plugin folder and stop/start domoticz... Really seems like something cached.. in latest dz plugin system sends 2 parameters instead 4 as was before.
thanks for the advice. done and not works.
I delete de folder with "sudo rm -Rf __pycache__" then stop/start and the problem persist
Does this script/plugin works for the second generation (international version) or only with the first gen ?
@kurairaito
I don't have 2nd, but someone said that python-miio lib works with 2nd version, so should be ok if so..
I can confirm, Domoticz V 8747 is still crashing
Anyone an idea?
Quaxx
2017-11-28 06:53:31.255 (Mi Robot EG) Sending 8 bytes of data:
2017-11-28 06:53:31.255 (Mi Robot EG) 91 a6 73 74 61 74 75 73 .. .. .. .. .. .. .. .. .. .. .. .. <91>¦status
2017-11-28 06:53:31.257 Error: /home/pi/domoticz/domoticz() [0x2336f0]
2017-11-28 06:53:31.257 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x2337a8]
2017-11-28 06:53:31.257 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c616b0]
Quaxx
It seems that every python plugin are crashing on beta version on domoticz.
I had to go back to stable, because beta has memory leaks, and python does crash.
Now you are running server outside domoticz, could you backport this to stable ?
I think it should work...
EDIT : It seems I speak a bit too quickly.
I tried the last version of plugin on stable version of domoticz.
I had to download msgpack and put it into xiaomi-robot folder. This allowed me to run the plugin correctly.
Then I ran into "onMessage takes 2 arguments..." error, so I corrected the 3 lines containing this def with the same signature than the old version of the plugin... I had one successfull update of my xiaomi devices, but then I got "Error: Domoticz received fatal signal 11" at each startup....
So, even with stable version of domoticz, I'm still having crashes.
@napo7
Try updated version 0.1.3 of plugin (with fixes for 3.8153).
Tested only on dev env with Ubuntu for 3.8153 and 3.8755.
OK, just updated to 0.1.3 (on Domoticz 3.8755)
Will let You know if it fixes the issue...
Edit: running for about 5 hours now without issues. Keeping fingers crossed!
Still crashing (after about 12 hours)
@Quax1507
0.1.3 just have fix for support 3.8153.
I also have crashes of domoticz on the last beta (RPI3) with any plugin. Only on my dev env (ubuntu 16.04) with last beta works ok.
@mrinner
So ist's a problem with the python3 libs on Stretch?
@Quax1507
I think something with integration C and Python in Domoticz.
how is it possible to retriew the TOKEN for robot?
- BullHead
- Domoticz version: V3.8771
Hello!
When i try to runt test script during installation i get this message:
Is there a simple solution for this?
And yes, the robot has been set to a static ip number in the router.
And yes, MiHome app is able to talk to the robot on 192.168.1.16 ip number.
EDIT:
Got it to work now.
Solution = Reboot router
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.5/site-packages
test: trying connect to 127.0.0.1:22222
test: sent request to server [status]
test: reading response...
test: got server reply {'cmd': 'status', 'exception': 'python-miio: Unable to discover the device 192.168.1.16'}
EDIT:
Got it to work now.
Best regards
Jonas
Jonas
Firstly thanks for your work
hope it will work for me too.
I follow all your steps, the test say everything goes fine. But when I go to domoticz I don't have any Xiaomi vacuum robot available. Don't know why...
Do you have any recommandation?
Thanks in advance
Thanks in advance
@Noka
Did you add hardware with name 'Xiaomi Mi Robot Vacuum' in domoticz? If you did it - check the devices menu, all devices should be created anyway, with test or without. If test goed fine the plugin would works fine:)
When I want to add hardware I don't have the vacuum on the list. So I can't add it in domoticz :/ ! Am wrong ?
Can you show us the listing of the "plugins" directory inside your domoticz installation ?
In this folder, you should have a "xiaomi-robot" folder or so. Can you also show us the content of this folder ?
