Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
just query a device, and it re-syncs your devices
freakshock
Post by freakshock »
Hi Madgeni, I would love to test the skill as well. Email is freekl.. @gmail. Could you add me? Thanks!
Madgeni
Post by Madgeni »
freakshock wrote: Tuesday 28 November 2017 19:18 Hi Madgeni, I would love to test the skill as well. Email is freekl.. @gmail. Could you add me? Thanks!
added :)
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
Madgeni wrote: Tuesday 28 November 2017 16:50 the 'Controlicz name override' in the Domoticz description only provide a 'friendly name' for Google and Alexa, the actual names still apply
Funnily enough, I've changed the names in Domoticz to 'Living Room Lights' and 'Sofa Lights', again neither is in a room in the Home app and I can switch them on and off with Google but not set a dim level. I then tried another light and that won't dim either, they are LightwaveRF switches. Googles reply is either 'Sorry, it doesn't look like that device is not set up yet....' or 'Sure, setting <device> to <xx> percent brightness' but nothing happens to the light. Whilst the television volume via the 'Sony plugin by G3rard' slider switch works perfectly, Google still says brightness but it does the job.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Madgeni
Post by Madgeni »
ok, i'll take a look this evening
Thomasdc
Post by Thomasdc »
alanlsmith wrote: Tuesday 28 November 2017 20:00
you should try do say to dim your lights at a value around 4 %
does it work now? (for me, also rfxcom, it works between 0 and 16 % where 16 equals full brightness.. ) this was a problem i also had when i used the habridge..
Madgeni
Post by Madgeni »
I normalise those percentages Thomas, so that shouldn't be the issue.
alanlsmith
Madgeni wrote: Tuesday 28 November 2017 21:57 I normalise those percentages Thomas, so that shouldn't be the issue.
It does actually work now. Requesting 32% gives 100% brightness, 16% = 50% this is with the LightwaveRF switches.
I remember that in HA-Bridge I added a calculation to interpret 'real' percentages to the 0-32 that the switches required.
As I said the television volume works one to one with requested percentage and actual percentage.
Incidentally the mi-light LEDs also work when requesting 0-100%, so maybe it's just a foible of the LightwaveRF switches?
MichaelM
Post by MichaelM »
Could you please add me as well?
I created an account with email [email protected]
Would greatly appreciate it.
ebbspot
Post by ebbspot »
Hello Madgeni,
i would like to use (test) controlicz with my domoticz and google assistant. I am registred on controlicz with email eb*e*@xs4all.nl
Last edited by ebbspot on Thursday 30 November 2017 12:30, edited 1 time in total.
Raspberry Zero PI 3 B
Evohome wifi Evohome HGI80 Evohome Web
4x Rfxcom
Google AIY
Z-Wave
OpenPlotter
robdank1986
Post by robdank1986 »
Got google Home om my smartphone and nvidia shield , would love to do some testing. I have a controllicz account by almost the same name as my forum name.
Thanks in advance!
Madgeni
Post by Madgeni »
alanlsmith wrote: Tuesday 28 November 2017 22:16
that's the problem, i think i've handled all use cases, and then along comes another one! Let me see what I can do :)
alanlsmith
Madgeni wrote: Wednesday 29 November 2017 9:28
Sorry :oops:
ixionky
Post by ixionky »
Hi Madgeni,
Could you add me to the trial for Google Home please. The e-mail I've registered on Controlicz with is based on the username here.
Madgeni
Post by Madgeni »
done :)
MichaelM
Post by MichaelM »
Thanks for adding me to the beta.
I added the devices successfully and named the room "ventilation" and each button a different number from 0 to 3.
(I use domoticz to control my house's ventilation system)
When I say: "Hey Google turn on ventilation 1" , the google home confirms my voice command but nothing happens.
When I try to change the login on the controlicz site google assistant gives me an error, so the login and password were correctly filled in.
What might I have done wrong?
ultratoto14
Post by ultratoto14 »
MichaelM wrote: Wednesday 29 November 2017 22:24 Thanks for adding me to the beta.
Hi MichaelM, what is google home answering to your commands ?
It seems that the right command is :
"Hey google turn on 1 in ventilation"
https://support.google.com/googlehome/a ... 3578?hl=en
Step 5
Madgeni
Post by Madgeni »
Hi - had a PM from MichaelM - this is all fixed :)
MichaelM
Post by MichaelM »
Step 5
The voice command I use is: hey Google, turn on ventilation 1.
A few seconds later she answers, 'Sure, turning on 1'
Really surprised how fast and easy it was.
My problem was caused by an older version of domoticz.
Sent from my ONEPLUS A3003 using Tapatalk
ultratoto14
Ok, happy that that's working now for you.
U.
