Lua for PING with sleep
emme
Domoticz version: latest
Re: Lua for PING with sleep
Post by emme »
cannot really figure it out.... but...
I think os.execute will return the errorlevel for the command.... not for the reply of it..
os.execute('ping -c1 192.168.0.150') will always return true even if the ping is not successful because the command ping were executed with no error
anyhow... it runs with no error into my deomoticz installation...
UNLESS....
you delete the script while it is wtill runing... then I got such error :P
"We always done this way"
BakSeeDaa
Post by BakSeeDaa »
That script will stall the Domoticz event system. You don't want that. Don't do it.
JimmyH1969
Post by JimmyH1969 »
How about the integrated "System alive checker"?
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
In the first place I can't say how to do. Perhaps it is possible to set the script on or off with a virtual (timer) switch. I would like that option.
JimmyH1969
Just go to hardware and add the system alive checker.
When it's added you can configure it and add the ip adresses of all the systems you like to check and specify timeout's etc.
For every device you add a virtual switch is created. You can use that switch in other scripts like, when virtul switch is off (unable to ping that system) send a message, switch a light, whatever
JimmyH1969
:D
