Home Theatre Controller (Pioneer AVR + USB PowerMate)
sammyke007
Domoticz version: 2022.1
Re: Home Theatre Controller (Pioneer AVR + USB PowerMate)
Post by sammyke007 »
Hi guys. i've got a Pioneer VSX-S510 and I can connect to it over Telnet using port 8102. Using Putty (Telnet), I can query volume, mute, change input, ... So I guess this script should work for me.
Anyone go this working (installing) on Domoticz running on a Synology? Maybe with Debian chroot?
Kind regards
antipiot
Domoticz version: Stable
Post by antipiot »
Hello all!
Does any of you have experience or informations about the pioneer SX-S30DAB?
Can it be used with your script? or the scripte plugin manager?
Van00
Post by Van00 »
Ben je op zoek naar de beste PlayStation-controller? Dan kun je onze PlayStation-controller kopen. Onze controller levert het reactievermogen van 2,4 GHz draadloze technologie. Je kunt hem bedienen vanaf een afstand van maximaal 10 meter.
Loky31
Post by Loky31 »
First of all thanks for the work provided :)
Just a question regarding the CEC, is ther any possible way to manage TV and other device connected in HDMI and CEC capable through the Pioneer HC ?
It would be great to turn on or off throught a "controled" CEC ( most of the time CEC is acting like it wants on my side :lol: )
Thanks in advance for the answer :D
stlaha2007
Post by stlaha2007 »
sammyke007 wrote:Hi guys. i've got a Pioneer VSX-S510 and I can connect to it over Telnet using port 8102. Using Putty (Telnet), I can query volume, mute, change input, ... So I guess this script should work for me.
Kind regards
Hi there,
It's been a while, and in meanwhile switched over to Beta Domoticz which also has another hardware option to get it working. Working hreat for me now for a few months.
As i have no knowledge of tweaking Synology i'm unable to help or answer your question(s).
stlaha2007
antipiot wrote:Hello all!
If it can be controlled through the network with iControl-app it may possible.
Else look into the plugin hardware version as thats the one i switch to resendly.
JumpingRick
Post by JumpingRick »
stlaha2007 wrote: Friday 11 March 2016 23:18
nayr wrote:try updating, I havent tested it but it should be enough.
Did some testing on bigger screen...
Changing volumes of zones let to some strange behaviour... Zone2 indipended, until Master goes up, Zone2 Volume as well....
Eventually managed to modify server.js now MasterZone and Zone2 can be controlled independed
Only thing i cant find is why the slider for Zone2 in Domoticz still goes up when turning the MasterZone up. Fortunate the Zone2 Volume itself does not.
The following partial code i have modified:
	// Zone 2 Volume Switch
	if (data.idx === switches.z2volume) {
		if ((data.dtype !== "Light/Switch") || (data.stype !== "Switch") || (data.switchType !== "Dimmer")) {
			domoticz.log("[HTC] ERROR: Wrong Switch Type - " + data.name)
			console.log("DOMO ERROR: Wrong Switch Type - " + data.name)
			return 0
		val = parseInt(data.svalue1) + 1
		if ((val !== Z2VOLUME) && (Z2VOLUME) && (data.nvalue === 2) && (READY)) {
			if (TRACE) { console.log("DOMO: Zone 2 Volume " + val) }
			Z2MUTE=0
			Z2VOLUME=val
			receiver.volume2zone(val)
		} else if ((data.nvalue === 0) && (!MUTE)) {
			if (TRACE) { console.log("DOMO: Zone 2 Mute ON") }
			Z2MUTE=1
			receiver.mute2zone(true)
		} else if ((data.nvalue === 1) && (MUTE)) {
			if (TRACE) { console.log("DOMO: Zone 2 Mute OFF") }
			Z2MUTE=0
			receiver.mute2zone(false)
// receiver: zone 2 volume
receiver.on('volume', function(val) {
	if (TRACE) 				console.log("ZONE2 VOLUME: " + val + "%");
	clearTimeout(switchTimer)
	switchTimer = setTimeout(function() {
		if (switches.z2volume)		domoticz.switch(switches.z2volume,parseInt(val));
	}, 1700);
	Z2VOLUME=val
	READY=true
In particular VOLUME changed to Z2VOLUME
Thanks for sharing your code, it makes perfect sense to me from what I can read.
I had the same issue with SC-1228-K.
When I'm using the Dimmer Volume Switch for Zone 2, Zone 2 is getting muted.
Few questions to try to fix this:
  1. Anyone with clue where to look?
  • Each 10 minutes, something turns off Zone 2. From what I can see in "server.js" code, the receiver gets queried for power/input. Could it be there?
  • Maybe a nn00b question, but where can I find the messages loggued when "console.log()" is used in server.js and pioneeravr.js files?
Thanks again all.
