so, in your browser, make sure you don't have Domoticz open. Then can you log into your Domoticz as the account you want to start using. Then, in another browser tab type: https://yourhost:port/json.htm?type=devices&filter=all&used=true&order=Name - what devices does it discover?
This is *NOT* a controlicz issue, I don't do anything clever or fancy with the interaction with your Domoticz - I don't cache requests, or users. i use the account you provide, it will discover what you let it. If it's finding more devices than you would like it to, then it's config on your side
finally someone takes care of Domoticz and Google Assistant integration. Excellent!
Would this also work with a ssl Nginx reverse proxy with simple user authentication in front of a non passworded Domoticz? IFTTT works fine with https://user:[email protected]:443/domoticz. I can send all commands, also Domoticz android app works fine.
I wanted to sign up at controlicz.com, but wasnt sure what to enter at user, pass, port...
Thanks in advance!
Thanks in advance!
Hi there
It's interesting, i think you're not the first (you've finally given me the answer to some of the errors!) and yes it will work, BUT i'll need to make a change, as i expect https://hostname:port - whereas you give me https://hostname:port/domoticz..
Let me have a play tomorrow, see if i can work something out
update: it's going to be some effort - i created a node wrapper for the Domoticz API, and the connection string will need to be redone to handle this.
Should have it done in a couple of days, will let you know
Totally awesome,
thank you for your response and work!
Thx for your tip, finally i maybe have a source for this issue.Madgeni wrote:so, in your browser, make sure you don't have Domoticz open. Then can you log into your Domoticz as the account you want to start using. Then, in another browser tab type: https://yourhost:port/json.htm?type=devices&filter=all&used=true&order=Name - what devices does it discover?
User device assignation, works great ! But user can still use all the scènes and groupes.
Controlicz still can see all my groupes and scènes, and list them to Google Home.
As i don't have a Real good dsl connection, maybe request take to long Time to get all my device. I will try to create à small version of my installation.
http://domo-attitude.fr
Hi Madgeni
i would like to test contolicz with Google home PM me please
thanks
thanks
Hi deennoo - this does seem to be an issue for some, I guess I underestimated how many devices people have, also Google enforce a 5sec (I think) response from initial request, whereas Alexa is 10sec. This is a bit cheeky, as i've observed that there's about a 1 sec delay from asking Google to do something to it actually requesting it of Controlicz!
This is mostly an issue for query requests ("What lights are on?") or similar, which make lots of individual requests - am looking at a re-write, but it will take some time.
However, discovery of 100+ devices should still only take 1-5 seconds tops.
- Domoticz version: 3
I would like to help out in the beta. But i cant send Pm's yet because i'm new.
Domoticz v3 - Beta Channel @ Pi3 | Harmoney Hub | MiLight Ibox2 | Google Home (1) | Google Home Mini (3)
Hi deennoo,
Do you have a standalone domoticz install or do you use nginx to provide your APIs over internet ?
U.
Hi Madgeni,
I am also new to the forum and cannot PM you, would like to test the Google Home functionality.
also your email address that you use to send confirmation from controlix, does not work
register on Controlicz, and i'll pick your email up from thereevildonkey wrote: ↑Sunday 26 November 2017 7:46 I would like to help out in the beta. But i cant send Pm's yet because i'm new.
yep, it's currently send only - it's low on my list of priorities
That à standalone installation using domoticz serverultratoto14 wrote:Hi deennoo,
U.
Done that yesterdayMadgeni wrote: ↑Sunday 26 November 2017 11:57register on Controlicz, and i'll pick your email up from thereevildonkey wrote: ↑Sunday 26 November 2017 7:46 I would like to help out in the beta. But i cant send Pm's yet because i'm new.
give me a clue then! What are the first 4 characters?evildonkey wrote: ↑Sunday 26 November 2017 12:37Done that yesterdayMadgeni wrote: ↑Sunday 26 November 2017 11:57register on Controlicz, and i'll pick your email up from thereevildonkey wrote: ↑Sunday 26 November 2017 7:46 I would like to help out in the beta. But i cant send Pm's yet because i'm new.
thelast
gotcha
Oke, just wanted to let you know.
Followed the steps real easy. Added Controlicz. and there were all my lights (just to start with).
And every thing is working very smooth and fast.
Kudos to you sir.
Kudos to you sir.
awesome - thanks
- Domoticz version: v3-Beta
If there's still room I would like to help with the beta as well ... running Domoticz @ Pi2
Already registered with Controlicz on Friday
E-mail starts with domi
Thanks in advance!
Thanks in advance!
Domoticz v3 - Beta Channel @ Pi2 | RFXtrx433e | MiLight Box2 | Google Home (1) | Google Home Mini (2)
