MyDomoticz - Testers wanted!
Cees
Re: MyDomoticz - Testers wanted!
Post by Cees »
chimit wrote: Saturday 25 November 2017 13:17 Apologies people. A server configuration issue occurred after doing security updates.
Specifically monit kept wanting to reboot the server over and over again.
This has been fixed again. Your domoticz instance might need to be restarted in order to connect to mydomoticz again.
<= You are the best.
Yeppers, after a restart of my computers everything is working as before.
RedRaven
Post by RedRaven »
Thanks! Working now :)
RedRaven
Post by RedRaven »
Not working again :( Not able to connect.
ArnieO
Domoticz version: 4.9700
Post by ArnieO »
RedRaven wrote: Sunday 26 November 2017 17:34 Not working again :( Not able to connect.
Same here. No response from https://my.domoticz.com/
Electronics engineer partly out of practice, having turned the skills into hobby recently. Playing with RPi, Arduinos, ESP8266s etc. Installed Nexa units in the house, which I want to control with Domoticz / RPi3 / RFXtrx433.
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
bbos wrote: Monday 24 July 2017 11:27 Hi Pandy,
This is how I solved the issue:
I installed the program SQLiteDatabaseBrowserPortable.exe on my laptop.
Following I made a backup of my domoticz database.
After that I edited the database file using the SQLiteDatabaseBrowserPortable.exe tool.
In the database file I went in to the preferences part and there I removed all data which mentions MyDomoticz.
Following I loaded the modified database file in Domoticz.
Lastly I filled in the instance ID from MyDomoticz in the preferences of Domoticz (which previously was removed during the editing of the database file). And after that I started working again for me.
*note: make sure you keep a copy of the original database file, just in case something goes wrong.
Okay, peeps... Apologies for not having time to get with more mydomoticz updates frequently.
But this one seemed important enough to catch. I made two fixes to mydomoticz.
1. Once you deleted your domoticz instance from your dashboard, the next time it will automatically get a new instance id instead of complaining of not being able to log in.
2. On the fly I made a fix in the dashboard: Before, sometimes one wasn't able to delete an instance from the dashboard at all.
== Rene
chimit
Post by chimit »
Crash123 wrote: Monday 27 November 2017 7:45 It was online for 5minutes, since them it is offline again for me :?: :roll:
Right... Needed a double check on my latest fix. Trying once again.
RedRaven
Post by RedRaven »
Ah well. Down again :(
chimit
Post by chimit »
RedRaven wrote: Thursday 30 November 2017 17:39 Ah well. Down again :(
Yeah, the fix on the latest fix was fixed.
However, since a long time already, the daemon crashes in a manner that even the parachute process doesn't catch.
I know where in the code it happens but will need to find a way to reproduce still.
However, I won't be able to promise anything on when I will have time to debug completely. Apologies for that.
Meanwhile I will be monitoring the service and restart as neccesary.
== Rene
RedRaven
Post by RedRaven »
chimit wrote: Thursday 30 November 2017 18:00 However, I won't be able to promise anything on when I will have time to debug completely. Apologies for that.
== Rene
Thanks; it's working now. I hope you get a permanent fix for the crash early :)
RedRaven
Post by RedRaven »
Down :(
RedRaven
Post by RedRaven »
Down again.. :(
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Offline again... :(
RedRaven
Post by RedRaven »
Offline.. down.. we need to make this reliable. Today, I really needed to switch off a few devices and couldn't :(
sammyke007
== Rene
Rene
Any update from you? It is great to use... if it works :D :lol:
RedRaven
Post by RedRaven »
sammyke007 wrote: Thursday 28 December 2017 14:58
== Rene
Rene
Still down. Looks like I have to set up port bouncing..
jaha
Post by jaha »
Just signed up. And I only get at blank page, is there still a problem with the service?
Screen Shot 2017-12-29 at 15.44.05.png (91.27 KiB) Viewed 2749 times
jaha
Post by jaha »
jaha wrote: Friday 29 December 2017 15:50 Just signed up. And I only get at blank page, is there still a problem with the service?
Running beta. What can I do to get my devices to show up under dashboard?
RedRaven
Post by RedRaven »
Well. We are down again.. why is my.domoticz.com so unreliable :( Anything that can be done to make it more reliable?
michaldobrotka
Post by michaldobrotka »
+1 Can something be done to improve it?
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
YOYO
Domoticz version: V2.23393
Post by YOYO »
It seems mydomoticz is down for a few days already.
Is there a page where we can see that there are problems?
IS there a way for the community to help getting this more stable?
