I also have a question: I have two controllers but I cannot seem to select both it always gives me the first location although I select 1 or 2 or ... It creates those zones.
I use the Evohome via Web Api. Do I have to change something else?
Evohome client (August 2017 update)
- Target OS: -
- Target OS: -
Re: Evohome client (August 2017 update)
Settings are saved and it gets the information. It just seem to ignore the location setting
- Target OS: -
So nothing I can do probably?
- Target OS: -
Guess I'll have to wait a bit until it reaches the stable version. I'm using docker so I can't update to the beta .
- waaren
With every new Domoticz Beta version following 8627 is get the following error
2017-11-24 17:02:49.230 (Evohome) connect to Evohome server
2017-11-24 17:02:49.389 Error: (Evohome) HTTP client error at login!
I compile from source using a spare RPI. If I try to update using the updatebeta script I got segmentation fault (when run from command line) or Fatal signal 11 (daemon)
If I copy my version 8627 back it will connect and update my temperatures and setpoints so I assume settings in domoticz database are correct.
Is there a way to solve this ?
- Domoticz version: latest
I to had the issue of wrong login. After several attempt fixing the issue I logged in into totalconnect website. Edited my profile by changing the hungarian language to dutch. Hungarian is a good default honeywell!
After that I stopped and started the web api device in domoticz and it started connected my home
