combine if statement
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
is it possible and if so better to combine those lines that are for Scene statements:
    if
    domoticz.devices(56).lux < 350 and -- Lux
    domoticz.variables(7).value == 0 and -- Lux Variable
    domoticz.devices(65).state == 'Off' and -- Scene Goodnight
    domoticz.devices(59).state == 'Off' and -- Scene Evening
    domoticz.devices(62).state == 'Off' and -- Scene Movie
    domoticz.devices(61).state == 'Off' and -- Scene TV
    (domoticz.devices(85).state == 'On' or domoticz.devices(86).state == 'On') -- iPhone Sensors
    then
maybe you can combine them domoticz.devices(65,59,62,61).state == 'Off' ?
emme
Domoticz version: latest
Re: combine if statement
Post by emme »
that would be nice.... not only in the if statement, but i could be also
domoticz.devices(65,59,62,61).switchOn().checkFirst()
+1
"We always done this way"
dannybloe
Post by dannybloe »
First of all, I'd not use indexes like this as it makes your code hard to read (you always have to cross-reference it to figure out what is what). I'd create either a set of constants like local GOODNIGHT=65 and then use domoticz.device(GOODNIGHT) or local goodNight = domoticz.devices(65) and then if (goodNight.active and tv.active and move.active) etc.
I don't think I will add such a combined command but you can easily create one yourself using helper functions. Just pass in a table of ids or names and create a loop that will do it for you: domoticz.helpers.batchSwitch(domoticz, 'On', { 65, 59, 62, 61 })
poudenes
Post by poudenes »
dannybloe wrote: Friday 24 November 2017 9:01 First of all, I'd not use indexes like this as it makes your code hard to read (you always have to cross-reference it to figure out what is what). I'd create either a set of constants like local GOODNIGHT=65 and then use domoticz.device(GOODNIGHT) or local goodNight = domoticz.devices(65) and then if (goodNight.active and tv.active and move.active) etc.
Thanks for the example and the explanation. Ill go back to the dzVents documents :). You pushed me to right direction!
