Any problems or requests - let me know
Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Madgeni
Re: Google assistant/Google home integration
YES! I'm so pleased it's working for you
mark.sellwood
Hi, Its working for me too.
One question, if I add or remove a device from a room how do I get the change reflected in GH? So far I've been removing the plugin & re adding it.
You also said temperature was working, is this a set only function? I have tried to ask whats the Lounge temperature but I get a generic answer I don't know that but i'm learning etc.
Great project, thanks.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
Madgeni
Hi - google's resync is weird. Whereas Alexa runs background discoveries to keep a reasonably accurate list of devices, Google doesn't do that.
I trigger those resyncs everytime you do something - so if you query a device, that will refresh your device list.
Re: Temps - yes, it's working. I can both query a temp device ("What's the temperature of the <device>?", or if it's a room, "what's the temperature in the barn?")
mark.sellwood
Thanks, I'll have a go tonight when I'm home.
Madgeni
please do - if it doesn't work, drop me a PM, and i'll take a look at the logs and see what it's doing
Skippiemanz
- Domoticz version: 4.10233
Just got my first home mini inspired by this thread. Already signed up on controlicz. I will send you an email! Keep up the good work and let us know how we can by you a beer!
*Edit* Beer is on its way!
Madgeni
Thank you so much! Donations aren't just a nice thing (they are) but they go towards paying for the hosting of Controlicz - much appreciated
Skippiemanz
Any users here with a google home or home mini who got it working? i've followed the install steps and in the home app under manage accounts i've added the home controlicz. i now see 9 additional devices but i'm not able to control them by voice. am i missing something or?
deennoo
Did you use the same account that the one who register your Google Home ?Skippiemanz wrote: Wednesday 22 November 2017 22:57 Any users here with a google home or home mini who got it working? i've followed the install steps and in the home app under manage accounts i've added the home controlicz. i now see 9 additional devices but i'm not able to control them by voice. am i missing something or?
@Madgeni , I still have some probleme to show all my device, only 6 are show from 96 i have, it can be perfect if we can manage which one to drive with google home/Alexa, i don't care about PIR, or door sensor...Unfortunaly, choosing device in Domoticz user interface doesn't work...any idea on this ?
http://domo-attitude.fr
Skippiemanz
Yes, and i can see 9 devices in my home app. So the connection is there. But how do i speak a command to controlicz? if i say Hey google, Turn on the kitchen lights. there is no positieve reactiondeennoo wrote: Wednesday 22 November 2017 23:42Did you use the same account that the one who register your Google Home ?Skippiemanz wrote: Wednesday 22 November 2017 22:57 Any users here with a google home or home mini who got it working? i've followed the install steps and in the home app under manage accounts i've added the home controlicz. i now see 9 additional devices but i'm not able to control them by voice. am i missing something or?
flav
It s working for me.
On the home app,maybe try to assign them to a room and change their nickname. I tried with name completely différents like : "silver cat". It worked, then i choose something Closer to what i wanted
flav
As far as i understand, devices needs to be assigned to a plan in domoticz, and light switch "picture" in domoticz should be set to "generic"
flav
Skippiemanz
This is what I got in the Google Home App. What command do you give? OK Google, talk to controlicz? And then turn on silver cat?
Madgeni
Hi - it's misleading (not my fault) - you don't need to launch it - just say Ok Google - turn off the thing
Madgeni
You can assign the devices you want to control via Alexa/Google to the user that Controlicz uses. If you have 96 devices in room plans, and you're not seeing them, then there's a problem. I'll take a lookflav wrote: Wednesday 22 November 2017 23:52deennoo wrote: Wednesday 22 November 2017 23:42Did you use the same account that the one who register your Google Home ?Skippiemanz wrote: Wednesday 22 November 2017 22:57 Any users here with a google home or home mini who got it working? i've followed the install steps and in the home app under manage accounts i've added the home controlicz. i now see 9 additional devices but i'm not able to control them by voice. am i missing something or?
Working fine for me, I did find I needed to assign Temperatures to Rooms for them to work, lights\switches would work either way.
I also had a conflict with a sensor I have called "Inside Temperature" it would return all my temp sensors when I asked "What's the Inside Temperature" I renamed my room from Inside to House and now it works asking "What's the House Temperature". So there are some "names" that google seem to have reserved for some functions.
[/quote]
Ahhh this is an interesting thought for me, I was asking you able a filter option in description, but If I just remove access to my Controlicz users to any device I want filtered that should work?
Thanks,
Wob
Madgeni
yes
and it works a treat, I should have thought of that.. List is a little more manageable now.
