IKEA Anslut
schlabbe
IKEA Anslut
Post by schlabbe »
Hi there,
I'm pretty new to the whole home automation.
I've successfully set up Domoticz on my Synology and connected a RFXtrx433e.
Unfortunately I'm not able to integrate the IKEA Anslut LED bar.
I've seen that there is an entry in domoticz especially for Anslut.
But where do I get the required ID from?
Domoticz Anslut 1.png (38.92 KiB) Viewed 1429 times
I've tried also the automatic learning but without success.
It would be great if somebody had an instruction for dummys :-)
Best Regards
sion
Re: IKEA Anslut
Post by sion »
I though all the Ikea stuff was on zigbe, it then I did just notice the anslut on the supported rfxcom list.
Maybe you haven’t turned the protocol on on the Rfx hardware setup?
Got settings, hardware, select the rfxcom, then Set mode.
You will need to make sure that you have the right one ticked. ( you can have lots ticked ).
Most stuff seems to be on lighting4. So if that’s not ticked try that one First.
I don’t know what One you need for the Ikea stuff, so have a google and see what you can Find.
When I get stuck, I will try them all.
First up, make a note of what’s ticked so you can go back to where you are if needed.
Now tick them all, and see if it works.
If it does :
Un tick all the new ones you just ticked, then go through one at a time until you find the one you need :)
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
schlabbe
Re: IKEA Anslut
Post by schlabbe »
thank you very much for your answer.
Unfortunately that didn't work. Even with all protocols on I was not able to connect the Anslut Lighting.
I also used always the learning mode of the lighting.
I only can imagine that it the fault is in the wrong ID but I don't find any ID on the Anslut.
Perhaps any other ideas? :-)
Best Regards
