update rflink automaticly
- remb0
I found some nice script to automaticly update the rflink firmware.
https://github.com/roondar/RFLink-update/
who creates an wiki page with a how to?
- install scripts, give execution rights
- create a virtual switch of cronjob that runs update.sh
working of this script:
Creates a directory in RFLink tMP
- download newest version FW stable in / tmp / RFLink /
- Controles if avrdude andJQ are installed, if not: installs it automaticly
- Check the following info" (idx, serial port, name, versions)
- Updates FW
git clone https://github.com/roondar/RFLink-update.git
cd RFLink-update
sh ./update_RFLink.sh
credits to deennoo
- Updates FW
cd RFLink-update
credits to deennoo
Re: update rflink automaticly
Hi there.
This is a part of working script
Please be patiente, stunteam is looking to add it to domoticz for all distro
Original topic was here : https://easydomoticz.com/forum/viewtopi ... =22&t=2832
Maybe you can ask to Roondar him self !
Have you try it ?
.sh files is mine ! thank for it !
.py is Roondar one's
Roondar says that is looking for a better way about this script.
Roondar Python's one is better again, it solve the fw check probleme who existe on the sh one.
You have to install python and some dep : like psutil
On the bash one fw check is flase, and version update is hardcoded
On Python 's one Script check if their really a new fw and then update if necessary
Next big step is to check Domoticz port : actually both script are using port 8080, but syno can use 8084 and some advanced user can use custom port
if you want to help your welcome !
One thing about python :
You have to change :
to
Have you try it ?
l 19 : dry_run = True
l 19 dry_run = False
Last edited by deennoo on Thursday 01 December 2016 16:47, edited 1 time in total.
http://domo-attitude.fr
- Stuntteam
Yeah, wait until the developers of the script are done and everything is properly tested.
Btw, great work Deennoo, Roondar and all the others that are working on it..
I just updated my code https://github.com/roondar/RFLink-update
I use it for about 2 months now without issues.
Enjoy.
Enjoy.
- Domoticz version: BETA
Can this implement in Domoticz like the Rfxcom?
Or do i need a different script install?
I don't have any Rfxcom.Derik wrote:Can this implement in Domoticz like the Rfxcom?
The upgrade process of Rfxcom need a particular .exe
So, it won't be compatible with my script.
Re: RE: Re: update rflink automaticly
On domoticz running on a pi you can apply update direct from domoticz.roondar wrote:I don't have any Rfxcom.Derik wrote:Can this implement in Domoticz like the Rfxcom?
@Derick
Installation script be sure it can be run, then set a virtual pushon and put script://waytoyourscript/updaterflink.py on action ON.
Then set a planning for on every monday at 8:00 and forget it.
Update will be check and apply full auto.
- Domoticz version: current
Couldn't Domoticz be pre-packaged with lots of scripts (like the presence detection script too), and then manage the running of those scripts by itself, without Crontab? Then Domoticz could offer simple settings-pages for those scripts that set the parameters. Perhaps it could read a list of required parameters from the top of the script.
Well, it's already implemented in Domoticz with plugins but I think Domoticz dev team couldn't maintain them all.blauwebuis wrote:Couldn't Domoticz be pre-packaged with lots of scripts (like the presence detection script too), and then manage the running of those scripts by itself, without Crontab? Then Domoticz could offer simple settings-pages for those scripts that set the parameters. Perhaps it could read a list of required parameters from the top of the script.
So, as Deenoo said you can create a dummy button and trigger a script when you want.
@Deenoo
I see the upgrade firmware function in https://github.com/domoticz/domoticz/bl ... Serial.cpp.
My knowledge in C is very limited but, you need to provide a firmware file before upgrade ?
If someone have some link with how to upgrade rfxcom firmware's on Linux, I could be update my script.
Yes you have to choose your new Fw to update on rfx config page.
Really not do easy than your script.
Python plugin are still new and some changé have still to be made.
Be patient with this, and as this an open source, you can help if you want, be translate présence détection on domoticz plugin.
Just before think to all aviable possibility :
Hci dongle choice
Update refresh
Ble device auto discover
Lib needed for plugin with auto installation
Etc etc
Hci dongle choice
Update refresh
Etc etc
Sorry, I meant shell scripts specifically.
Great script, running every night so always up to date, THANKS.roondar wrote: ↑Saturday 25 March 2017 18:10 Hi all,
Enjoy.![]()
One question, how to modify it so I get an email when your scripts has update the rflink ?
From the official python documentation, there is a example at the bottom of the page.
import smtplib
def prompt(prompt):
return raw_input(prompt).strip()
fromaddr = prompt("From: ")
toaddrs = prompt("To: ").split()
print "Enter message, end with ^D (Unix) or ^Z (Windows):"
# Add the From: and To: headers at the start!
msg = ("From: %s\r\nTo: %s\r\n\r\n"
% (fromaddr, ", ".join(toaddrs)))
while 1:
try:
line = raw_input()
except EOFError:
break
if not line:
break
msg = msg + line
print "Message length is " + repr(len(msg))
server = smtplib.SMTP('localhost')
server.set_debuglevel(1)
server.sendmail(fromaddr, toaddrs, msg)
server.quit()
Don't miss to indent the code at the same level.
