Comparing stored time with lastUpdate
jsiegmund
Post by jsiegmund »
Help! I've been messing around with time objects but I can't seem to get it to do what I need it to :)
Basically what I want to calculate is the time between the activation of a PIR sensor and the last update. So what I did:
- When the PIR activates (and triggers the lights) I store the datetime in a global var like this:
local Time = require('Time')
local currentTime = Time().raw
domoticz.globalData.eye01Activation.add(currentTime)
The reason I use raw in this example is mainly because I could not get it to work...
- Next I have a script which triggers every minute and checks the lastUpdate of the PIR sensor:
local lastUpdate = eye01.lastUpdate
local lastActivationRaw = domoticz.globalData.eye01Activation.getLatest().data
domoticz.log('LAST ACTIVATION RAW: ' .. lastActivationRaw)
if (lastActivationRaw ~= nil) then
	local lastActivationTime = Time(lastActivationRaw)
	local minutesActivated = lastUpdate.compare(lastActivationTime)
	domoticz.log('MINUTES ACTIVATED: ' .. tostring(minutesActivated.minutes))
So eye01 is my sensor from which I get the lastUpdate. Next I construct a Time object with the value stored in the global data. This value is correct, I've checked that. Then I try to compare those things. It all works, but the result of minutesActivated.minutes is a nil value. Why? I was expecting the number of minutes of difference between the two time objects. Any ideas?
Disclaimer: I removed some lines which were not relevant to reproduce the issue. It might not compile like this, did not check, the idea is clear I hope :)
dannybloe
Re: Comparing stored time with lastUpdate
Post by dannybloe »
Oh dear, I just noticed that I made a mistake in the documentation for the compare function. It is not .minutes but .mins (same for .secs and .ms). Sorry about that but that explains why you get the nil error.
Having said that.. why do you store the lastUpdate value manually and not just access it in your timer script from the device:
	local ago = domoticz.devices('eye01').lastUpdate.minutesAgo
That should work or something else is wrong.
jsiegmund
Post by jsiegmund »
dannybloe wrote: Tuesday 21 November 2017 7:24 Oh dear, I just noticed that I made a mistake in the documentation for the compare function. It is not .minutes but .mins (same for .secs and .ms). Sorry about that but that explains why you get the nil error.
The reason I do this is that I want to store the time the PIR activated the lights. I do this to enable the following scenario:
- I quickly walk into a room. Lights go on by PIR activation. Walk out again, after 1 min the lights go out.
- I work in a room for a couple of hours. Walk out of the room. Lights stay on at least 10 minutes, I might come back or I'm sitting still so the PIR doesnt notice.
To do this, I need to calculate the amount of time between the first activation and the last time the PIR was updated. That will amount to the total 'activity time' inside that room, so that's the reason I'm storing it.
Thanks for the info, I'm sure I'll get it working now. BTW I personally would find "minutes" more logical than "mins" anyway.
htilburgs
Post by htilburgs »
Would be nice if you like to share when you're ready.
Have a simular situation soon with a PIR and I like this approach!
Hardware:
dannybloe
Post by dannybloe »
The reason I use mins instead of minutes is that for lastUpdate etc it is also min, sec, hour etc. That's the same as standard Lua time functions.
jsiegmund
Post by jsiegmund »
Sure? I'm pretty sure I was using lastUpdate.minutesAgo up to now.
Freemann
Domoticz version: >=Béta
Post by Freemann »
This is working for weeks now;
    on = {timer = {'Every 5 minutes'}},
    execute = function(domoticz)
        if (domoticz.devices('RegenSensor1').lastUpdate.minutesAgo >= 15 and domoticz.devices('RegenSensor1').state == 'Off') then
            domoticz.devices('RegenSensorMain').switchOff()
            domoticz.notify('Het doet niet regenen')
So also usings the minutesAgo
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
jsiegmund
Post by jsiegmund »
htilburgs wrote: Tuesday 21 November 2017 12:52 Would be nice if you like to share when you're ready.
Sure, no problem. I've made the habit to put everything in a github repo, so you'll find it there in a couple of days once I have everything working :) https://github.com/jsiegmund/domoticz-dzvents
jsiegmund
Post by jsiegmund »
@dannybloe any comment on the differently named lua stuff?
dannybloe
Post by dannybloe »
yeah, it's minutesAgo. That's correct if that's what you mean. Not what I meant though.. But it is what it is :)
jsiegmund
Post by jsiegmund »
dannybloe wrote: Monday 27 November 2017 20:34 yeah, it's minutesAgo. That's correct if that's what you mean. Not what I meant though.. But it is what it is :)
Haha no. What I mean is that it's minutesAgo and not minsAgo. So the minutes/mins thing is starting to get a little confusing, it should be one or the other.
Anyways; I've updated my repo with the now working scripts! Feel free to use it. https://github.com/jsiegmund/domoticz-dzvents
dannybloe
Post by dannybloe »
Yeah, you are right. I added seconds/minutes/milliseconds in the next update. (min/sec/ms will still be available).
jsiegmund
Post by jsiegmund »
dannybloe wrote: Monday 27 November 2017 21:10 Yeah, you are right. I added seconds/minutes/milliseconds in the next update. (min/sec/ms will still be available).
Superb, thanks!
