problem with forEach function
Kerel
Post by Kerel »
This code is not working properly for me:
		devices = {
            'All lights'
		timer = {
	execute = function(domoticz, device, triggerInfo)
		local lightsDownstairs = domoticz.devices().filter(function(device)
                return  (device.name ==
                                        'Sofa light' or
                                        'Dining room light' or
                                        'TV light' or
                                        'Hallway light' or
                                        'Kitchen light'
		if triggerInfo.type == 'device'
		then
		        print('trigger = device')
		        print('devicename = ' .. device.name)
		        if device.name == 'All lights'
		        then
		                print('Device state: ' .. device.state)
		                if device.state == 'On'
		                then
                                lightsDownstairs.forEach(function(light)
                                        print('Do something with ' .. light.name)
                                        light.switchOn()
                                        light.switchOff()
It seems it runs the lightsDownstairs.forEach(function(light) loop only for the first device in the array (which is 'Sofa light'). But I want it to run through all the devices in the array..
My log says:
2017-11-19 10:38:04.813 User: Admin initiated a switch command (99/All lights/On)
2017-11-19 10:38:04.881 dzVents: Info: Handling events for: "All lights", value: "On"
2017-11-19 10:38:04.881 dzVents: Info: ------ Start internal script: Light switch events: Device: "All lights (Virtual switches controller)", Index: 99
2017-11-19 10:38:04.909 dzVents: trigger = device
2017-11-19 10:38:04.909 dzVents: devicename = All lights
2017-11-19 10:38:04.909 dzVents: Device state: On
2017-11-19 10:38:04.909 dzVents: Do something with Sofa light
2017-11-19 10:38:04.909 dzVents: Info: ------ Finished Light switch events
Any thoughts?
Kerel
Re: problem with forEach function
Post by Kerel »
It turns out, this does seem to work:
                -- return  (device.name ==
                --                         'Sofa light' and
                --                         'Dining room light' and
                --                         'TV light' and
                --                         'Hallway light' and
                --                         'Kitchen light'
                return (device.name == 'Sofa light' or
                        device.name == 'Dining room light' or
                        device.name == 'TV light' or
                        device.name == 'DHallway light' or
                        device.name == 'Kitchen light')
But I'm not really fond of this way of coding.
dannybloe
Post by dannybloe »
You can make a table and use that in your filter.
	local lights = { 'Sofa light', 'Dining room light' }
	local _ = require('lodash')
		return _.includes(lights, device.name)
	end)
Users browsing this forum: Doler and 1 guest
