All crashed - help needed Topic is solved
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
I have the Aeotec Zw090 Gen5 Stick on my Pi running with domoticz. I had 3 different parts associatet, a garage Door Detector, a sensative strip for window opening and a fibaro Motion Sensor. All worked perfect. Then I bought 7 new sensatice window strips and insertert the first one. Worked. Then I saw, I had to do it again, because I wantet a secure insert. So I removed the sensor in the z-w-wave panel of domoticz and tried to insert it again. Didn't work. Did it again with a second one, same problem. Then I restored my pi from backup, but this didn:t help too. Then resetted the z-wave Controller, everything has gone, but I can't insert the old stripes. I had also a backup of the controller I did in the z-wave control-panel , but there's no
possibility to import this backup-xmll file. I don't know what to do. Shall I reset the Z-wave stick once again. Can I rest the sensor strips? Now at I the moment I have no morre ideas what I can do. Can anybody help?
harrykausl
Re: All crashed - help needed
Now after a complete reset I have 3 Sensative Strips connected. My arage-door sensor also works again. But I cant reinclude my fibaro motion sensor V3.2. Trede it several times, resettet the sensor completly, repaired network in z-wave. Noting helps. Has anyone any idea.
harrykausl
After several tries the motion sensor and the strip are included again.
