I have a Z-wave wall plug that I would like to turn on for 15 minutes, then off for 15 and so on. This would be repeated action. There are times in switch that could do this but I would have to manually add every entry there for a whole day, right? I also tried this from blockly (if plug=off, then turn on for 15 minutes) but it didn't work that way.
Any ideas?
Turn switch on and off repeatedly
Re: Turn switch on and off repeatedly
dzvents using last update to check if the switch have been on for more than 14minutes run the script every minute.
Thanks Clemen! That worked. Now I am trying to figure why it works that way
When I tell the script to turn on switch for 15 minutes that's logical, but is the default "reverse" action to turn it off because I dont have to define that. Gotta read more about dzvents, it seems very handy.
