Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
- gijsje
- Domoticz version: Stable
Re: Google assistant/Google home integration
If i say change all lights to orange they turn to blue.
purple and green and white are working
I only have mylights in the house
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
Madgeni
hah - ok. I've had to perform the conversion from Google -> Domoticz for hue - clearly needs work
Madgeni
what does this do to one of those lights?
https://hostname:port/json.htm?type=command¶m=setcolbrightnessvalue&idx=IDXOFTHELIGHT&hex=FFA600&brightness=100&iswhite=false
- gijsje
Thats orange
Madgeni
Colours are now working
mich423
Hello Madgeni,
I am interested for your solution. Could you integrate me to your team to test it ?
Thank you
Thank you
Madgeni
sure - PM me your email address, i'll set you up and give you the details
mich423
I am a new user, and it's not possible to use PM for this time
Madgeni
register at www.controlicz.com - and i'll email you the details
mich423
Hello Madgeni, it's OK.I am registered at www.controlicz.com. My name on controlicz is "mich423"
Madgeni
email sent - let me know how you get on
jeremie
I would be intested to test Controlicz with Google Home. How should I do ?
Thanks !
Thanks !
Madgeni
Just PM me your email address - and register at www.controlicz.com
jeremie
Sorry, as a new user here I cannot PM you. I'm registered on Controlicz with an email like [email protected]. I hope you will find me
Madgeni
got you
email on it's way
flav
I'd be interested in testing contolicz as well. my email is with [email protected]
I'm registering on the controlilicz website now.
I'll find a way to activate https for domoticz for my syno.
is uid user id ? Can we setup only one user in domoticz ?
thank you
thank you
Madgeni
Hi - email sent
UID = domoticz username. You can create as many users as you like in Domoticz - just make sure the one you use for Controlicz has access to the devices you want to discover in Google Home/Google Assistant.
Let me know how you get on!
Madgeni
hi -
it needs to be an email address associated with an active Google Account or Google Apps account - or so Google tells me
flav
I got it setup and it works like a charm. Thank you very muchMadgeni wrote: Tuesday 21 November 2017 21:42 Hi - email sent
FYI, My google home is in french, and commands in french works fine.
It's awesome and way faster than iftt
