PI or NAS
har0543
Domoticz version: 2022.2
PI or NAS
Post by har0543 »
I have Domoticz running on a Raspberry pi. This works ok although I have some "database disk image is malformed" errors sometimes.
I also have an Synology NAS. I installed Domoticz on it and changed one sensor to it.
This works.
Question is now: What is the best system to run Domoticz on a Pi or a NAS, in therms of energy consumption and reliability?
Harry
EdwinK
Re: PI or NAS
Post by EdwinK »
Energy-wise I would say the PI is using less power then the Synology. Realibily wise I think they both are the same.
Siewert308SW
Domoticz version: Stable
Re: PI or NAS
Post by Siewert308SW »
For 1.5 years i run my root from a Seagate 1TB Expansion HDD on my Pi3.
No need for extra powered HUB and never saw any corrupt database or anything else.
Made this choice after 2 corrupt sd-cards in 6 months and happy a turned over.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
EdwinK
Re: PI or NAS
Post by EdwinK »
Siewert308SW wrote: Tuesday 14 November 2017 16:40 For 1.5 years i run my root from a Seagate 1TB Expansion HDD on my Pi3.
That will be the next step. Still got a 2TB Seagate drive somewhere. Can be used for this. First figure out how-to do this
Siewert308SW
Re: PI or NAS
EdwinK wrote: Tuesday 14 November 2017 16:56
Depends on how many amps the HDD is asking.
My Seagate drive ask for .48 amps so it is usable without a extra powered USB hub.
Some drive do ask more then you have to use a USB powered hub.
As for a how to:
viewtopic.php?t=14525
Setup:
- rootfs @ USB HDD
Siewert308SW
Re: PI or NAS
gordonb3 wrote: Tuesday 14 November 2017 18:49
Beware! If you hear a `ping` or clicking noise at regular intervals (say ~10 seconds) then you're drive is killing itself. You may also be able to feel the associated movement inside the drive by touching the encasing. To verify you can run the following command:
smartctl -d ata -a /dev/sda
(or whatever device designation the drive received)
Watch for the line that says `Load_Cycle_Count`. You will likely see a ridiculously high number there that may already be far above the manufacturer's life expectancy specifications. What this means is that your drive may die on you any second now. If you want to run your Pi (or a plug computer) like this you shoud use a proper encasing with passive cooling and a NAS specification drive. Which will effectively even use less power than the `green` expansion drive, even though the specifications may state otherwise.
Drive never clicks, runs smoothly for 1,5 years now.
I did a lot of rebooting and APM is disabled each time my Pi reboots since 2 months.
I bought the drive somewhere in 2014 so the stats don't worry me.
Although the Load_cycle_count is 377441 isn't something i worry about as the expected Load_cycle_count is approx at 600000
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Momentus SpinPoint M8 (AF)
Device Model:     ST1000LM024 HN-M101MBB
Serial Number:    S30CJ9CG347506
LU WWN Device Id: 5 0004cf 20f76a5b3
Firmware Version: 2BA30003
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Nov 14 19:11:43 2017 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(12060) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 201) minutes.
SCT capabilities: 	       (0x003f)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       11003
  3 Spin_Up_Time            0x0023   092   090   025    Pre-fail  Always       -       2672
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1335
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   252   252   051    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       9070
 10 Spin_Retry_Count        0x0032   252   252   051    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       356
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1336
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       629
192 Power-Off_Retract_Count 0x0022   099   099   000    Old_age   Always       -       1215
194 Temperature_Celsius     0x0002   064   057   000    Old_age   Always       -       31 (Min/Max 21/44)
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   252   252   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       19255
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       356
225 Load_Cycle_Count        0x0032   063   063   000    Old_age   Always       -       377441
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%      9070         -
# 2  Short offline       Completed without error       00%      9070         -
# 3  Extended offline    Interrupted (host reset)      50%      8365         -
# 4  Extended offline    Completed without error       00%      4119         -
# 5  Short offline       Completed without error       00%      4116         -
# 6  Extended offline    Aborted by host               90%      4116         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Completed [00% left] (0-65535)
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Setup:
- rootfs @ USB HDD
HansieNL
Re: PI or NAS
Post by HansieNL »
Running Domoticz on a Raspberry Pi with a external SSD. Rasbian is installed via BerryBoot to SSD and then installed Domoticz. Running smoothly for more than a year now.
I had a read-only sd-card twice before, that's why I choose for a SSD solution.
Blah blah blah
freakshock
Re: PI or NAS
Post by freakshock »
So is there any reason not to run Domoticz on a NAS like a Synology if it runs 24/7 anyway?
Siewert308SW
Re: PI or NAS
freakshock wrote: Tuesday 14 November 2017 21:26 So is there any reason not to run Domoticz on a NAS like a Synology if it runs 24/7 anyway?
If your keen on power consumption, maybe?
Setup:
- rootfs @ USB HDD
Egregius
Domoticz version: v2024.7
Re: PI or NAS
Post by Egregius »
If the Syno runs 24/7 anyway and it isn't one of those cheap models run it there.
Otherwise a Pi is a good solution if you keep good backups in case of SD failure.
I used both but switched to a Intel Nuc, running Debian in a container on Proxmox. Hasn't ran faster than this before AND it's very easy to take complete system snapshots.
koowee
Re: PI or NAS
Post by koowee »
Do you have any experience of these small SSD drives with RPi or is this about same that normal USB memory stick?
https://www.amazon.com/Kingspec-Speed-S ... B00JF0AVJ6
EdwinK
Re: PI or NAS
Post by EdwinK »
Those look nice. And cheap. No experence with any ssd. Hope they are good, then i might buy me one.
har0543
Re: PI or NAS
Post by har0543 »
Thanks for all the kind responses.
As my NAS is always on I changed to the NAS version.
In the NAS are two WD Red WD40EFRX, 4TB drives.
Is it wise to use an USB drive for the database and/or backups to reduce the use of the drives in the NAS
regards,
Harry
heggink
Domoticz version: 12451
Re: PI or NAS
Post by heggink »
Wd have a pi specific drive which I use for 2 pi's. Power much better than 3.5 drive since it's a 2.5". As to green vs red, there is a wd setting to disable the idle timer on greens (wdidle3) . Did that for my freenas system. Whilst the red's are sold for nas, they are internally identical and over priced (for the exact same URE rate). Worked great and has been running for years with no increase in LCC.
DASHTICZ 🙃
P1 meter & solar panel
BakSeeDaa
Re: PI or NAS
Post by BakSeeDaa »
Siewert308SW wrote: Tuesday 14 November 2017 16:40 Made this choice after 2 corrupt sd-cards in 6 months and happy a turned over.
Just curious, I never had problems with any SD card ever. What brand/model of SD card did you use? Was it really a class 10 of good quality or was it one of those cheap chinese "no name" SD-cards that gets bundled for free? (No need to say, the latter is useless of course)
Personally I would never use anything else but Sandisk Extreme PRO micro SD when it comes to SD-cards. (Not, "Ultra", not just "Extreme" but "Extreme PRO") But that's me. It would typically cost you a few bucks more.
Cheers!
Siewert308SW
Re: PI or NAS
BakSeeDaa wrote: Thursday 16 November 2017 8:42
Cheers!
No Chinese stuff.
Had SanDisk class 10 32gb ultra and a Samsung class 10
Setup:
- rootfs @ USB HDD
heggink
Re: PI or NAS
Post by heggink »
Personally, I would never run any system that I really depend on (NAS, Domoticz) off of an SD card anyway unless I can guarantee that the SD card is not written to an a (semi-)regular basis. SD cards are not meant to run OSes. When you want logging and such, you can run things remote (remote syslog server) but, when things crash, a lot of the buffering is lost (typically the latest info leading up to the issue). I have become so dependent on domoticz that, for me, SD cards are no valid option. SSD probably yes, HDD same thing.
DASHTICZ 🙃
pvm
Domoticz version: 4.10538
Re: PI or NAS
Post by pvm »
A nas can support a raid drive configuration. A hard drive crash even doesn't cause an issue in that way
heggink
Re: PI or NAS
Post by heggink »
pvm wrote:A nas can support a raid drive configuration. A hard drive crash even doesn't cause an issue in that way
Depends on the size of the disk, it's URE rate and the type of raid. You wouldn't be the first one to see a disk fail and the resilver stop because of an error on the remaining disks. Disk sizes nowadays exceed URE rates leading to definite disk errors. 10^14 is the standard where 10^15 should be the norm. If Red drives would have that then they would be worth it but they have the same as greens.
DASHTICZ 🙃
heggink
Re: PI or NAS
Post by heggink »
Maybe but, having gone through a number of failing drives over the years, resilvering beats restore by a large margin. Still, backups are key whether nas or domoticz.
DASHTICZ 🙃
