Domoticz MQTT - OpenSSL error - mosquitto tls version
tuxmartin
Post by tuxmartin »
I have problem with TLS version.
My mosquitto TLS config:
# MQTT over TLS/SSL
listener 8883
cafile /etc/mosquitto/ca_certificates/ca.crt
certfile /etc/mosquitto/ca_certificates/server.crt
keyfile /etc/mosquitto/ca_certificates/server.key
require_certificate false
tls_version tlsv1 # = tlsv1.0 tlsv1.1 tlsv1.2
If I connect using:
mosquitto_pub -h server.example.net -p 8883 -t test/pokus -m 'abc' --cafile /ca.crt -u 'test' -P 'test'
I got error Error: A TLS error occurred.
An in mosquitto log:
1509365431: New connection from ::1 on port 8883.
1509365431: OpenSSL Error: error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version
1509365431: OpenSSL Error: error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure
1509365431: Socket error on client <unknown>, disconnecting.
If set tlsv1 param, it works:
mosquitto_pub -h server.example.net -p 8883 -t test/pokus -m 'abc' --cafile /ca.crt -u 'test' -P 'test' --tls-version tlsv1
In Domoticz there is no tls version config. In log I see:
1509365981: New connection from 127.0.0.1 on port 8883.
1509365981: OpenSSL Error: error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version
1509365981: OpenSSL Error: error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure
1509365981: Socket error on client <unknown>, disconnecting.
How can I fix it?
Domoticz v3.8153
Ubuntu 16.04 (armbian, orange pi)
mosquitto 1.4.12-1
RadioAir
Re: Domoticz MQTT - OpenSSL error - mosquitto tls version
Post by RadioAir »
I'm having the exact same issue. What I tried to resolve it (but failed):
-Setting TLS version hardcoded to TLS1.0/1.1/1.2 (on TLS1.2 the connection to my MQTT SonOff devices broke), this didn't work
-Updating OpenSSL to newest version available on apt-get: OpenSSL 1.0.1t 3 May 2016 (Library: OpenSSL 1.0.2l 25 May 2017)
-Compiling OpenSSL 1.1.0 but this failed with an error
-Trying to connect as localhost/IP of Raspberry (OSMC)
It seems Domoticz does the handshake in a way that OpenSSL/Mosquitto does not understand properly. I can connect to Mosquitto using the terminal with my ca.crt just fine so that does not seem to be the problem.
As I really would like to use MQTT with SSL, is there any way to fix this? :)
