sailmich
@robgeerts
Sorry my mistake you are right I tested now with beta, everything is working perfect. Seems I mixed it a little bit, with stable I have the problem as described before. Beta is running.
Sorry again and thanks for your support.
DAVIZINHO
hello.
i have the last stable version update from github with "git pull"
Its posible to update with last beta branch without delete and install again?
woody4165
If you want, you can have both and then decide.
just
where dashboard is a folder name of your choice.
Then just copy what's in stable folders "custom" and "custom_2" (and so on if you've created more) to the same folders in new beta and should be working.
just
git clone https://github.com/robgeerts/dashticz_v2 --branch beta dashboardThen just copy what's in stable folders "custom" and "custom_2" (and so on if you've created more) to the same folders in new beta and should be working.
DAVIZINHO
Ok, now im using the beta and the blocktitle now is adjustable in lenght. GREAT!!!!
the unique problem for me is a xiaomi sensor, (temp, humidity and air presure) that not show the air presure in dashticz_v2
Re: Dashboard returns to second screen
Solved .Thnx
dagger38
- Domoticz version: 3.8153
Strange??
the clock in the topbar from the regular domoticz runs 45 minutes behind , dashticz clock is ok , but when i setup timers , i have to add 45 minutes to get it to work ok??
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
woody4165
Am I wrong that I don't see anymore RGB support for yeelight in latest beta?woody4165 wrote:@robgeerts thanks for latest beta.
Now RGB is working also for Yeelight!!!
How can I check on which version I am and if I'm using beta or stable?
mantoz
- Domoticz version: 2024.7
Dashticz - Problem on Raspberry Pi: no sensors/actuators displayed
Hi guys,
I'm new to the forum and now I'm here asking for some help.
I started automating my home and I'm currently using Domoticz and I find it just great.
The system is working flawlessly so far: I have several temperature sensors, one motion sensor, automated blinds and a Philips Hue system for a couple of rooms. As an exercise, I started installing Domoticz at my holiday house as well.
Now I'm trying to add Dashticz.
While at the holiday house it worked very easily (it's running on a Linux Ubuntu Server), I am facing a problem on my Raspberry Pi3: I'm not able to display any sensor nor actuators. I just get the BlockTitle, the clock, other additional info, but no data from the sensors nor actuators (and no icons are displayed). Of course they are all present & working in Domoticz (and many are in the Domoticz dashboard as favorites).
I tried toggling the config[] variables in CONFIG.js (in particular 'auto_positioning' and 'use_favorites') but to no avail.
I'd like to debug the issue, but I don't know (and didn't find) any info to know if a detailed logfile is available somewhere.
Anyone had a similar issue and can give me some hints?
Thanks (any comment is welcome)!
Ciao,
mantoz
Ciao,
mantoz
CaesarPL
Re: Dashticz - Problem on Raspberry Pi: no sensors/actuators displayed
Hi, are you 100% sure that you have uncommented config file?
mantoz
Hi CaesarPL,
thanks for your reply.
I am sure that I uncommented CONFIG.js, tried many times to change various params and I see the changes after reloading the page.
But nothing from the sensors...
The differences between Dashticz on Ubuntu server (working) and Raspberry are probably many. I also tried re-installing Dashticz, but it's still not working.
Using latest Dashticz beta and Domoticz 3.8614 on Raspberry Pi3 and Dashticz stable and Domoticz 3.8590 on Ubuntu Server.
CaesarPL
Even if there are differences, in my opinion Dashticz should work...
FrankDutch
connection problem
I want to make thi great dashboard work on an i pad. But the dahboard doesn't sync with domoticz. Can any one help me?
config['domoticz_ip'] = 'http://xxxxx:[email protected]:8090';
robgeerts
- Domoticz version: 3.7067
Re: connection problem
I see you are using username and password in the url..
This wont work in some browsers anymore!
try:
Yes, you will have to enter the username and password in a prompt when loading Dashticz...
try:
config['domoticz_ip'] = 'http://192.168.1.167:8090';
mantoz
Yeah, I think so as well.... but as of today, no sensors on Dashticz.
Maybe something is broken in my installation, or I need to install something more that is installed by default on Ubuntu (the working installation).
I get no error messages from Dashticz, is an option available to get some more debugging info?? That would be very useful!
Thanks,
mantoz
Thanks,
mantoz
mantoz
After some additional tinkering I was able to get the sensors displayed in Dashticz.
To be totally sincere, I don't know exactly why now it works
Anyway, I just restarted from scratch with CONFIG.js and set only the very basic config, as suggested in the Installation section of the wiki:
Now I'll try to get a nice-looking dashboard without auto-positioning.
Thanks,
mantoz
Maybe was just setting the language to 'nl_NL' ?var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://192.168.x.xx:808x';
Thanks,
mantoz
evandenboom
Hello
I am using the default installation of Dashticz on an Rpi. Everything is working fine except the Font Awesome.
I would like to use this for various icons.
The font files do exist on the server and I bij viewing the source in the browser I can see that they are "loaded".
I used the syntax i found in various examples on this forum, like:
Elliot
- Spoiler: show
Elliot
- EdwinK
- Domoticz version: BETA
I think it should be
if you use underscore in your blocks
var blocks ={}
blocks['64_2'] = {}
blocks['64_2']['width'] = 4;
blocks['64_2']['title'] = 'Solar Totaal';
blocks['64_2']['icon'] = 'fa-sun-o';
evandenboom
Thanks for the quick response. But unfortunately still no icon.
pvm
- Domoticz version: 4.10538
What code is behind the buttons? How to configure this?sailmich wrote:@robgeerts
In addition more details.
Button for screen 2 -> screen 5
Button 3 -> screen 1
Button 4 -> screen 2
Button 5 -> screen 3
Autoback_swipe_to 1 -> screen 5
Autoback_swipe_to 2 -> screen 1
When I set 3/4/5/1 I get 2/3/4/5 exectly what I need. Before beta no problems 1 -> screen 1 ..........
FrankDutch
i have tried that but it doesn't work. no popup
the trange thing is that when i put the config.js in the notworking state the i get the connection with Domoticz
the ipad don´t get a connection either way (it is an ipad 1)
