In have domoticz running on a Pi for some years. Mostly with esp8266 switches and Sensors.
I started with some 433Mz units and the rfxcom transceiver. I bought a starter set von KAKU. (1500R)
Domoticz has found the units. I was able to switch the lights all for just once within Domoticz . After that no response.
In the log in I find: 2017-11-12 10:35:56.009 Error: RFXCOM: Invalid data received!..
What can cause this error?
Kind regards.
Har
KAKU does not work in Domoticz
- Target OS: -
Re: KAKU does not work in Domoticz
The remote is received as AC device?
You have a recent firmware in the RFXtrx433E?
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
- Domoticz version: 2022.2
AC device is correct. Firmware is on latest version.
I change the firmware from ext2 to ext. And now it works. Which is odd ass in both version the AC is part off the firmware
- Target OS: -
The code of your KAKU remote is maybe the same as a Kangtai/Cotech packet. If Lighting4 and AC is enabled in Ext2 it will try to decode the packet for this protocol.
