MQTT/ ESP8266 Multi-sensor
hb100
Post by hb100 »
I followed the instructions of Ben from Bruh automation to make a Mulitsensor for ~€10,-. See https://github.com/bruhautomation/ESP-M ... ultisensor
It works perfectly within Home Assistant, but....I would like to make it work in Domoticz. I tried several things, without any succes. If someone can help me, please.
I uses beta Domoticz and tried to follow this instructions: https://www.domoticz.com/wiki/MySensors ... TT-gateway
I did update the code of the senor:
/************* MQTT TOPICS (change these topics as you wish) **************************/
#define light_state_topic "domoticz/in/MyMQTT"
#define light_set_topic "ddomoticz/in/MyMQTT"
Result is that I see that domoticz is pinging to MQTT server, but this didn't do the job.
Thanks in advance,
Jeroen
mlamie
Domoticz version: 3.5877
Re: MQTT/ ESP8266 Multi-sensor
Post by mlamie »
I use ESPEasy for my ESP8266 boards. Really easy to use and natively supported in combination with Domoticz. https://www.letscontrolit.com/wiki/index.php/ESPEasy
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
accel
Post by accel »
@hb100 Maybe you already fixed it. But for everybody else. Take a look here:
http://www.sigmdel.ca/michel/ha/domo/domo_03_en.html
