Disarm or Ignore Door Switch
Underdog85
Post by Underdog85 »
Need some help trying to figure this out.
I have a bedside wireless switch which turns on/off the bedside lamps and a door sensor which automatically turns the lamps on when opened after sunset.
The issue: When I press the wireless on/off switch the lights go off but then when I open the door they turn back on.
Is there a way I can disarm the door sensor for 30 seconds and then re-arm the door allowing me to exit the room without them tuning back one?
emme
Domoticz version: latest
Re: Disarm or Ignore Door Switch
Post by emme »
sure...
you can use dzVents to work on lastUpdate value....
		devices = {
			'myDoorDevice'
		local lampSwitch = domoticz.devices('myLampSwitch')
		local delay = 30 --delay in secs
		if device.lastUpdate.secondAgo > delay then
			lampSwitch.switchOn().checkFirst()
by this... the door sensor will NOT switch on the light for the next n secs (based on the value set on delay)
"We always done this way"
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Or in plain Lua.
	function timedifference(s)
		year = string.sub(s, 1, 4)
		month = string.sub(s, 6, 7)
		day = string.sub(s, 9, 10)
		hour = string.sub(s, 12, 13)
		t1 = os.time()
		return difference
	if devicechanged["door_switch"] == 'Open'
		and otherdevices["bedside_light"] == 'Off'
		and timedifference(otherdevices_lastupdate["light_switch"]) >= 30
	then
		commandArray["bedside_light"]='On'
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Underdog85
Thanks both.
I don't have any experience with programming so the above doesn't make any sense to me. Is there a way you can break it down so I know where to insert my devices etc and how I go about this?
