dagger38
- Domoticz version: 3.8153
Works at last , copyed it in to the WWW dir , starts with /dashticz/index.html
Thanks , htilburgs and the others for info!!
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
MsbS
Quick question (probably trivial). I have a custom sensor, but it is not clickable - I would like to see a graph when I click it (like e.g. for temperature readings). When I create a graph tile ('graph_[IDX]') it works fine, so the data is there.
Lexfontes
Re: Swipe button
Not yet, may be I'll try to use otherl customs pages with an index page for my main menu and differents html pages.
dagger38
Strange???
Dasticz is running , on a windows browser page AND on my samsung tablet..
Any changes i make in : /home/pi/domoticz/www/dashticz/custom/CONFIG.js file have absolutely NO effect on the running dasticz?
Why?
Why?
My system:
1 Raspberry Pi 3
1 Milight module
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
dagger38
wow. IM stupid!, all the config.js is comented!
My system:
1 Raspberry Pi 3
1 Milight module
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
- EdwinK
- Domoticz version: BETA
You are not the first one, and I guess not the last one either who forgot to uncomment the config.js file.
DAVIZINHO
Re: Swipe button
hello, this is a good idea.
Today i need buttons to navigate because the swipe in my tablet is laggy.
Mi solution is make bigger the circles in the botton of dashticz. If this is a good solution for you, tell me and i share the howto
Where to get google maps api key ?
Because my map doesn't work yet I wonder if I have the right API-key.
I got it from https://developers.google.com/maps/docu ... et-api-key
Is that correct ?
Is that correct ?
Full screen on IPAD when using spotify
I learned from this forum that when using the spotify module, I have to open spotify in the same browser as Dashticz
In that case it is not possible to show the Dashticz dashboard fullscreen as far as I know.
Anyone managed to show the dashboard fullscreen on an IPad ?
Justinn
I am having some issues with dashticz hope someone is able to solve my problem.
I can create everything and dashticz is connected to domoticz because I see the sunrise and sunset but it shows no devices in dashticz? I have them as favorite in domoticz.
My Config:
hope someone can help me! thanks in advance
Justinn
My Config:
var config = {}
config['domoticz_ip'] = 'ip:port';
config['app_title'] = 'Domoboard';
config['domoticz_refresh'] = '2';
config['dashticz_refresh'] = '2';
config['auto_positioning'] = 0;
config['standby_after'] = 0;
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['slide_effect'] = 'slide';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['boss_stationclock'] = 'RedBoss';
config['wu_api'] = 'API';
config['wu_city'] = 'City';
config['wu_name'] = 'Weer in City';
config['wu_country'] = 'NL'
config['last_update'] = 1;
config['hide_topbar'] = 1;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['selector_instead_of_buttons'] = 1;
config['garbage_company'] = 'cure';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'ZIP';
config['garbage_street'] = 'Street';
config['garbage_housenumber'] = '2';
config['garbage_maxitems'] = '12';
config['language'] = 'nl_NL';
config['use_favorites'] = 1;
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 10 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
{"track":5,"name":"Vastelaovend","file":"http://www.radiovastelaovend.nl/templates/rav/luister.m3u"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
buttons.buienradar = {width:22, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['key'] = 'blocktitle_2';
blocks['blocktitle_2']['title'] = 'Weer';
blocks['104'] = {}
blocks['104']['key'] = '104';
blocks['104']['title'] = 'TV';
blocks['104']['switch'] = true;
blocks[233] = {}
blocks[233]['key'] = '233';
blocks[233]['device'] = 'TV';
blocks[233]['switch'] = true;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [233]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['clock','sunrise',buttons.nunl,buttons.nos,buttons.radio,buttons.buienradar]
columns[2]['width'] = 2;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_2','weather',tvguide.dutch,publictransport.ovinfobus]
columns[3]['width'] = 5;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[1]['background_morning'] = 'bg6.jpg';
screens[1]['background_noon'] = 'bg6.jpg';
screens[1]['background_afternoon'] = 'bg6.jpg';
screens[1]['background_night'] = 'bg6.jpg';
screens[2] = {}
screens[2]['background'] = 'bg3.jpg';
screens[2]['background_morning'] = 'bg_2.jpg';
screens[2]['background_noon'] = 'bg_2.jpg';
screens[2]['background_afternoon'] = 'bg_7.jpg';
screens[2]['background_night'] = 'bg_7.jpg';
screens[2]['columns'] = [4,5,6]Justinn
- HansieNL
Have you already tried to set ['auto_positioning'] = 1;
Blah blah blah
Re: Where to get google maps api key ?
Addes these lines and now it works. But what is the use of the vars then ?
var maps = {}
maps.location = { height: 400, width:15, latitude: 53.260860, longitude: 6.395335, zoom:11}-
Lexfontes
Re: Swipe button
Hi Davizinho,
Yes, I'm interested by this option. Thank's to share .
DAVIZINHO
Re: Swipe button
hello again,
I find that the width and height of the buttons are located in this file:
/dashticz_v2/vendor/swiper/css/swiper.min.css
I edit the swiper.min.css and modify this class:
.swiper-pagination-bullet { }
with this dimensions:
width: 80px;
height: 80px;
you must try with diferents width and height you like
width: 80px;
height: 80px;
FrankDutch
I have the same problem and i don't know how to solve itdagger38 wrote: Friday 03 November 2017 19:40 Strange???
Why?
var config = {}
config['domoticz_ip'] = 'http://192.168.1.***:8***';
config['dashticz_refresh'] = 1;
config['news_scroll_after'] = '7';
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['standard_graph'] = 'day';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['gm_api'] = '';
config['gm_zoomlevel'] = '0';
config['gm_latitude'] = '4.696699';
config['gm_longitude'] = '52.521445';
config['wu_api'] = '7df899576e906077';
config['wu_city'] = 'Uitgeest';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['garbage_company'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 1;
config['hide_topbar'] = 0;
var trashnames = {}
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/ ... ive_96.mp3"},
var buttons = {}
var blocks = {}
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather','garbage']
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
this is the config could someone help me?
dagger38
Take away the ./* Line 1 and the */. On the last line
Same as I sit wrong
Same as I sit wrong
My system:
1 Raspberry Pi 3
1 Milight module
1 Niko home system
1 Raspberry Pi 3
1 Milight module
1 Niko home system
FrankDutch
thx
that sis the trick
that sis the trick
BennyV
Has anyone had this problem before? Working fine on Laptop/Pc but no devices seen on tablet or iphone
BennyV wrote: Friday 27 October 2017 12:12 I've set up Dashticz. I can see and use my devices on pc/laptop. But when I open it on a tablet or iphone I can't see any devices.
What can be my problem?
My config.js:
var config = {} config['language'] = 'nl_NL'; config['timeformat'] = 'DD/MM/YYYY HH:mm'; config['domoticz_ip'] = 'http://xxxxxxxxxxxxxx'; config['app_title'] = 'Dashticz'; config['domoticz_refresh'] = '5'; config['dashticz_refresh'] = '60'; config['wu_api'] = 'xxxxxxxxxxxx'; config['wu_city'] ='Gruitrode'; config['wu_country'] = 'Belgium'; config['wu_name'] = 'Gruitrode'; config['use_favorites'] = 0; var trashnames = {} trashnames['Gft'] = 'GFT'; trashnames['Pmd'] = 'Plastic'; trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT var publictransport = {} publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 } var tvguide = {} tvguide.dutch = { key:'dutch', icon: 'fa-television', width:12, channels: [49,59,60], maxitems: 10 } var _STREAMPLAYER_TRACKS = [ {"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"}, {"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"}, {"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"}, {"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"}, ]; var buttons = {} buttons.hbvl = {key: 'hbvl', width:4, icon: 'fa-newspaper-o', title: 'HBVL', url: 'http://www.hbvl.be'} buttons.hln = {key: 'hln', width:4, icon: 'fa-newspaper-o', title: 'HLN', url: 'http://www.hln.be'} buttons.sporza = {key: 'sporza', width:4, icon: 'fa-newspaper-o', title: 'Sporza', url: 'http://www.sporza.be'} var blocks = {} blocks['blocktitle_buiten'] = {} blocks['blocktitle_buiten']['key'] = 'blocktitle_buiten'; blocks['blocktitle_buiten']['type'] = 'blocktitle'; blocks['blocktitle_buiten']['title'] = 'Buiten'; blocks['blocktitle_gelijkvloers'] = {} blocks['blocktitle_gelijkvloers']['key'] = 'blocktitle_gelijkvloers'; blocks['blocktitle_gelijkvloers']['type'] = 'blocktitle'; blocks['blocktitle_gelijkvloers']['title'] = 'Gelijkvloers'; blocks['blocktitle_boven'] = {} blocks['blocktitle_boven']['key'] = 'blocktitle_boven'; blocks['blocktitle_boven']['type'] = 'blocktitle'; blocks['blocktitle_boven']['title'] = 'Boven'; blocks['blocktitle_onder'] = {} blocks['blocktitle_onder']['key'] = 'blocktitle_onder'; blocks['blocktitle_onder']['type'] = 'blocktitle'; blocks['blocktitle_onder']['title'] = 'Onder'; blocks[40] = {} //achterdeur blocks[40]['width'] = 4; blocks[39] = {} //voordeur blocks[39]['width'] = 4; blocks[38] = {} //kelderdeur blocks[38]['width'] = 4; blocks[65] = {} //garage buiten blocks[65]['width'] = 4; blocks[66] = {} //Terras living blocks[66]['width'] = 4; blocks[67] = {} //Terras keuken blocks[67]['width'] = 4; blocks[54] = {} //voordeur sfeer blocks[54]['width'] = 4; blocks[50] = {} //aanrecht blocks[50]['width'] = 6; blocks[49] = {} //keuken blocks[49]['width'] = 6; blocks[51] = {} //sfeer blocks[51]['width'] = 12; blocks[52] = {} //zithoek blocks[52]['width'] = 6; blocks[53] = {} //eethoek blocks[53]['width'] = 6; blocks[55] = {} //bureau blocks[55]['width'] = 4; blocks[56] = {} //inkomhal blocks[56]['width'] = 4; blocks[64] = {} //Garage blocks[64]['width'] = 4; blocks[48] = {} //berging blocks[48]['width'] = 4; blocks[47] = {} //sas blocks[47]['width'] = 4; blocks[58] = {} //Toilet blocks[58]['width'] = 4; blocks[72] = {} //Rol omhoog blocks[72]['width'] = 6; blocks[72] ['icon'] = 'fa-arrow-up'; blocks[73] = {} //Rol omlaag blocks[73]['width'] = 6; blocks[73] ['icon'] = 'fa-arrow-down'; blocks[59] = {} //Overloop blocks[59]['width'] = 4; blocks[57] = {} //overloop sfeer blocks[57]['width'] = 4; blocks[60] = {} //Emily blocks[60]['width'] = 4; blocks[61] = {} //Ryan blocks[61]['width'] = 4; blocks[62] = {} //Slaapkamer blocks[62]['width'] = 4; blocks[63] = {} //Dressing blocks[63]['width'] = 4; blocks[69] = {} //Douche blocks[69]['width'] = 4; blocks[70] = {} //Badkamer blocks[70]['width'] = 4; blocks[71] = {} //Lavabo blocks[71]['width'] = 4; blocks[68] = {} //Zolder blocks[68]['width'] = 4; blocks[78] = {} //Trap blocks[78]['width'] = 4; blocks[77] = {} //Voorraad blocks[77]['width'] = 4; blocks[74] = {} //Droogkast blocks[74]['width'] = 4; blocks[76] = {} //Container blocks[76]['width'] = 4; blocks[80] = {} //Werkbank blocks[80]['width'] = 4; blocks[75] = {} //Dompelpomp blocks[75]['width'] = 4; blocks[79] = {} //Waterpomp blocks[79]['width'] = 4; blocks[41] = {} //Kodi blocks[41]['width'] = 12; var columns = {} columns['bar'] = {} columns['bar']['blocks'] = ['logo','miniclock','settings'] columns[1] = {} columns[1]['blocks'] = ['blocktitle_buiten',40,39,38,65,66,67,'blocktitle_gelijkvloers', 50,49,51,52,53,55,56,64,48,47,58,72,73] columns[1]['width'] = 4; columns[2] = {} columns[2]['blocks'] = ['blocktitle_boven', 59,57,60,61,62,63,69,70,71,68, 'blocktitle_onder',78,77,74,76,80,75,79] columns[2]['width'] = 4; columns[3] = {} columns[3]['blocks'] = ['currentweather_big','weather','sunrise', 41, buttons.hbvl, buttons.hln, buttons.sporza] columns[3]['width'] = 4; var columns_standby = {} columns_standby[1] = {} columns_standby[1]['blocks'] = ['clock','weather'] columns_standby[1]['width'] = 12; var screens = {} screens[1] = {} screens[1]['background'] = 'bg2.jpg'; screens[1]['columns'] = [1,2,3]
CaesarPL
To be sure, set config['auto_positioning'] = 0;, don't know what is the default.
Lexfontes
Re: Swipe button
Thank you.
