Slimme meter/Smart meter cable stopped.
KruisR
Post by KruisR »
Hi. I have Domoticz running for a few months by now and from all the things that don't work my "Slimme meter" smart meter cable P1 has always worked. This morning at 4 o-clock it suddenly stopped. In Domoticz it states 0 watt is used with should be a good thing but it isn't.
I checked the cable and checked it from the console. After getting the info from the cli it states the following reading:
0-0:96.1.1(4B414C37303035303932373339363132)
1-0:1.8.1(05431.272*kWh)
1-0:1.8.2(05272.195*kWh)
1-0:2.8.1(00360.212*kWh)
1-0:2.8.2(00817.630*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(0000.18*kW)
1-0:2.7.0(0000.00*kW)
0-0:17.0.0(0999.00*kW)
0-0:96.3.10(1)
0-0:96.13.1()
0-0:96.13.0()
And every 30 second (or so) it updates. So this means that the cable is working and Domoticz isn't.
I am running along with the beta's and i am currently on:
V3.8688
Build Hash: bc0a53d5-modified
Build Date: 2017-11-01 21:52:08
Anybody else has this problem and or has a solution?
KruisR
Re: Slimme meter/Smart meter cable stopped.
Post by KruisR »
Well the complete message is as followed:
/ISk5\2ME382-1003
1-0:1.8.2(05274.370*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(0000.47*kW)
0-0:96.3.10(1)
0-0:96.13.1()
0-0:96.13.0()
That is at least something extra. Is it complete now?
KruisR
Post by KruisR »
Well that's a good question. I haven't seen anything at the forum about this issue.
I ordered a second cable and will test it with another RP after i get it with a non beta version of Domoticz to view if that will be working.
KruisR
Post by KruisR »
After the update i just got the problem is solved. All back to normal again (for now) :)
KruisR
Post by KruisR »
Well that was temporarily. 🤔
DomoJev
Post by DomoJev »
gordonb3 wrote: Is there anyone else experiencing this issue?
Maybe. I see similar behaviour on my installation but thought it was a problem with jessie; P1 is the only sensor hooked up to a spare RPi running domoticz as slave to the main system located on the 2nd floor.
It hangs every 3 or 4 days with domiticz going offline. I don't have time to investigate further; simply added a cron job that checks domoticz every 5 minutes and restarts the deamon if it sees 0 on all 4 values (I have a double tariff meter with return from solar).
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I have the exact same problem after a recent update.
Went from the last stable to beta.
Before that the P1 cable worked without any problem for a year or 2.
Now there is no correct data in Domoticz, but if I read out the P1 datagrams on the same Pi they are fine.
So it has to be a problem in Domoticz.
The meter is a DSMR 2.2 meter spitting out the following every 10 seconds:
/KMP5 ZABF00xxxxxxxx
0-0:96.1.1(205A4142xxxxxxxxxx)
1-0:1.8.1(16724.157*kWh)
1-0:1.8.2(07520.622*kWh)
1-0:2.8.1(03649.990*kWh)
1-0:2.8.2(08631.503*kWh)
0-0:96.14.0(0002)
1-0:1.7.0(0000.50*kW)
1-0:2.7.0(0000.05*kW)
0-0:96.13.1()
0-0:96.13.0()
0-1:24.1.0(3)
0-1:96.1.0(32383030393xxxxxxx)
0-1:24.3.0(171108100000)(00)(60)(1)(0-1:24.2.1)(m3)
(05579.935)
The datagrams look good to me, also there is just one gas meter present.
In Domoticz there is no correct gas usage anymore, or only a faulty value once every day.
Power display in Domoticz is often f.i. 5747293847292847623762623 instead of something real.
KruisR
Post by KruisR »
After the beta update at the beginning of this week the problem has been solved. Everything was working pretty nice again. After the update of this evening the temperature sensors are not listed anymore. So after the next update where everything looks working again i am off the beta's..... ;)
bbqkees
Post by bbqkees »
Here the P1 meter is also working again.
Users browsing this forum: pfloryann and 1 guest
