device trigger time-rule constraint
mutley
Post by mutley »
I know this is really basic and silly question to ask, but I can't seem to find the right syntax for this command. I'm trying to use the 'at nighttime' constrain on a device trigger.
The documentation gives this as an example.
on = { devices = { ['myDevice'] = 'at nighttime' } }
This is my code
    active = true,
        devices = { [
            'Driveway Cam Motion',
            'Front Door Cam Motion',
            'Back Door Cam Motion',
            'Back Garden Cam Motion'
           ] = 'at nighttime'
    execute = function(domoticz, switch)
The error I get
Error: dzVents: Error: error loading module 'motion' from file '/data/home/domoticz/scripts/dzVents/scripts/motion.lua':
/data/home/domoticz/scripts/dzVents/scripts/motion.lua:15: '}' expected (to close '{' at line 10) near '='
Line 10 is 'device=...'
Line 15 '] = 'at nighttime'
I realize I can put the time test in the execute part, but the whole point of using dzVents is to stop this code getting executed unless absolutely necessary. I have a very elaborate motion trigger / light setup that I wrote in C using MQTT events because of the limitations using previous versions of scripts in Domoticz and having to be executed on every event, dzVents looks like the perfect reason to port this.
mosjonathan
Re: device trigger time-rule constraint
Post by mosjonathan »
this is the i'm using it:
    active = true,
		devices = {
	      ['PowerOff'] = {'at 21:30-03:00'},
mutley
Post by mutley »
Thanks. You gave me a hint. Needed to list each time constraint independently. Which makes it a lot more powerful.
    active = true,
        devices = {
            ['Driveway Cam Motion'] = {'at daytime'},
            ['Front Door Cam Motion'] = {'at daytime'},
            ['Back Door Cam Motion'] = {'at daytime'},
            ['Back Garden Cam Motion'] = {'at daytime'}
dannybloe
Post by dannybloe »
Yes, you have to provide a table for the device-time constraints as you can have multiple constraints per device.
Users browsing this forum: Bing [Bot], hemant5400z and 1 guest
