Dashticz - Custom JS
jake
Post by jake »
Section for Custom.jss questions
jake
Re: Dashticz - Custom JS
Post by jake »
In my custom.js I have defined for a long time that a energy consumption block 142_1 will receive a green background when my solar panels cause a 'negative' value. This works fine.
My problem now is with my 2nd trial: based on switch/block 80, I want block 181 to change color when this switch/block 80 = 'On'. Unfortunately this doesn't work, unless when I change the if statement to the one of the energy block (which of course doesn't make sense), than the block changes color correctly. What is wrong in my custom.js?
custom.js:
//add custom javascript in here
function afterGetDevices(){
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
function getStatus_142_1(idx,value,device){
if(parseFloat(device['UsageDeliv'])>0){
$('div.block_142_1').addClass('terugleveren');
else {
$('div.block_142_1').removeClass('terugleveren');
function getStatus_80(idx,device){
if(parseFloat(device['Status'])=='On'){
$('div.block_181').addClass('gasgebruik');
else {
$('div.block_181').removeClass('gasgebruik');
custom.css:
CUSTOM CSS FILE
.fa.fa-lightbulb-o.on {
color:#F1C300;
.fa.fa-lightbulb-o.off {
color:#fff;
.fa.fa-fire.on {
color:#f00000;
.fa.fa-fire.off {
color:#fff;
.title{
font-size:15px;
.fa-lightbulb-o:before{
font-size: 24px;
.trash .state div.trashrow {
font-size: 12px;
.trash .state div.trashtoday {
font-size: 15px;
.trash .state div.trashtomorrow {
font-size: 13px;
.publictransport div {
font-size: 15px;
.terugleveren {
background: rgba(85,255,105,0.3) !important;
background-clip: padding-box;
.gasgebruik {
background: rgba(255,128,128,0.3) !important;
/* Calendar font modifications with icon active */
.col-xs-10.items { font-size: 13px;
/* Calendar font modifications with NO icon active */
.col-xs-12.items { font-size: 13px;
UPDATE:
I found the solution:
In my innocence ;-) I didn't realize what parsefloat meant in the custom.js file. Only today I googled it and... understood:
Instead of:
I now have changed it into:
if(device['Status']=='On'){
Now I also understand why Dasticz was able to calculate with the
because when I run the json command to retrieve all paramaters, the 'UsageDeliv' is shown as xyz Watt and not just xyz. The 'parsefloat' function strips the first number out of a string for use in calculations.
htilburgs
Post by htilburgs »
I like to change the textcolor of the lastupdate to red, when lastupdate is computed more than 2 hours ago.
@robgeerts provided me with the custom.js code:
function getStatus_153(idx,value,device){
	if(moment(device['LastUpdate']).unix()<(moment().unix()-(3600*8))){
		$('div.block_153').addClass('lu_warningred');
	else {
		$('div.block_153').removeClass('lu_warningred');
custom.css:
.lu_warningred {
	color: red !important;
But the problem is I only like the textcolor of lastupdate to change, and not the complete block. I've tried and tried, but no luck.
I personally think the problem is in the $('div.block_153').addClass('lu_warningred'); part, but I can't seem to find the solution.
Anybody?
Schermafbeelding 2017-11-15 om 11.49.21.png (11.35 KiB) Viewed 4730 times
Hardware:
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Could you try the following:
custom.js:
		$('div.block_153 .lastupdate').addClass('lu_warningred');
	else {
		$('div.block_153 .lastupdate').removeClass('lu_warningred');
Maybae you also have to do this in custom.css
.lastupdate.lu_warningred {
EdwinK
Post by EdwinK »
Screen Shot 2017-11-15 at 20.59.15.png (28.33 KiB) Viewed 4704 times
I have this one. This block stays red, whether 'ketel' is on or off. I want it to be red only if it's on. Tried it with the solution for the 'aanwezig' button
Screen Shot 2017-11-15 at 21.01.18.png (29.69 KiB) Viewed 4704 times
, but somehow that isn't working
htilburgs
Post by htilburgs »
robgeerts wrote: Wednesday 15 November 2017 20:55 Could you try the following:
custom.js:
	else {
No, doesn't work :-(
Hardware:
robgeerts
Post by robgeerts »
I tested this in custom.js, and that does work...
I had to add a timeout, otherwise it couldnt do that because that block didnt have content yet..
	setTimeout(function(){
		if(moment(device['LastUpdate']).unix()<(moment().unix()-(3600*2))){
			$('div.block_153 span.lastupdate').addClass('lu_warningred');
		else {
			$('div.block_153 span.lastupdate').removeClass('lu_warningred');
	},1000);
htilburgs
Post by htilburgs »
Hi Rob,
If I use the last code with the timeout function, than it works for me to:
		else {
	},1000);
.lastupdate.lu_warningred{
But when I do the same without the forced timeout, nothing happens while there is a timeout?!
</s>function getStatus_153(idx,value,device){
	if(moment(device['LastUpdate']).unix()<(moment().unix()-(3600*1))){
		$('div.block_153 span.lastupdate').removeClass('lu_warningyellow').addClass('lu_warningred');
	else {
		$('div.block_153 span.lastupdate').removeClass('lu_warningred').addClass('lu_warningyellow');
Strange, isn't it??
Hardware:
robgeerts
Post by robgeerts »
"But when I do the same without the forced timeout, nothing happens while there is a timeout?!"
Uhhhh... say what?
htilburgs
Post by htilburgs »
Yip, that’s what I say.
Hardware:
robgeerts
Post by robgeerts »
Je zegt dat als je het zonder timeout doet er niks gebeurd terwijl je wel een timeout hebt...
You say it does nothing without a timeout but you do have a timeout
htilburgs
Post by htilburgs »
Klopt, zonder het timeout script in het script, terwijl er wel een timeout is gebeurt er niets....;-)
Right, without the timeout command in the script, while I have a timeout, nothing happens....;-)
current entry in config.js
	else {
current entry in custom.css
.lu_warningred{
current json output
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 18,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 7,
         "HardwareName" : "Dummy Virtual Switch",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "000140E9",
         "Image" : "Phone",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-11-16 15:50:02",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "iPhone Nassira",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "627",
         "YOffset" : "370",
         "idx" : "153"
Hardware:
DewGew
Domoticz version: V4.10618
Post by DewGew »
I have add icon fa-spinner for one of my devices (pump). When i put it in like this:
blocks[123]['icon'] = 'fa-spinner';
- Icon is not rotating
blocks[123]['icon'] = 'fa-spinner fa-spin';
- Icon is rotating
Is it possible to add the class "fa-spin" only when device is on with custom.css and custom.js?
robgeerts
Post by robgeerts »
@DewGew, kun je dit eens proberen:
function getStatus_123(idx,value,device){
		if(device['Data']=='On'){
			$('div.block_123 .col-icon .fa').addClass('fa-spin');
		else {
			$('div.block_123 .col-icon .fa').removeClass('fa-spin');
	},1000);
@htilburgs, but where is the timeout coming from then?
Why dont you add it to the 'getStatus_153'-function?
DewGew
Post by DewGew »
@robgeerts, Thanks I try that :) but it seems that custom.js is not loading in lataste beta??
robgeerts
Post by robgeerts »
I saw you did a PR with a fix for the loading? did you try my code after it?
DewGew
Post by DewGew »
robgeerts wrote:I saw you did a PR with a fix for the loading? did you try my code after it?
I havent tested latest beta only own setup. Seems to work here.
htilburgs
Post by htilburgs »
For my iPhone devices I like to change the text "AAN" and "UIT" to "AANWEZIG" and "AFWEZIG". For this I have a custom.JS part
I've havent't used this for a while and this used to work, but for some reason it doesn't work anymore.
I can't find out where the issue is.
// Function for modified status - iPhone Harm
function getBlock_150(device,idx){       //idx 150 - iPhone Harm
   $('.block_'+idx).attr('switchDevice(this)');
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
      else html+=iconORimage(idx,'fa-toggle-on','','on icon');
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
   // check if device has show_last_update=true
   if((_SHOW_LASTUPDATE && (typeof(blocks[idx])=='undefined' || typeof(blocks[idx]['hide_lastupdate'])=='undefined' || blocks[idx]['hide_lastupdate']===false)) ||        (!_SHOW_LASTUPDATE && (typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['show_lastupdate'])!=='undefined' && blocks[idx]['show_lastupdate']==true))  )
   html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
   html+='</div>';
   return html;
Hardware:
EdwinK
Post by EdwinK »
I've send you mine, but... not sure if it works anymore. Didn't check it in ages.
htilburgs
Post by htilburgs »
With the help of Edwin, I've narrowed down my problem. When I leave the lastupdate part out of the code, it works.
   html+='</div>';
So, now the question is: how to get this working again with the lastupdate part... ;-)
Hardware:
