Nefit Easy™
SweetPants
Re: Nefit Easy™
Post by SweetPants »
mvveelen wrote: Friday 29 September 2017 18:19 1. do others have the same issue?
Yes. sometimes it goes fine for weeks, then you see errors in domoticz.log
mvveelen wrote: Friday 29 September 2017 18:19 2. how can I automate this detaching: I want the 2-wires that run to the Nefit to be disconnected for a few seconds and reconnect again using a Wemos D1 Mini or something like that: someone who can give me a hint on how I can do that?
Because I have an older type of boiler, it uses a separate box powered with an adapter. As soon as I detect the Bosch Backend being unreachable, I power off/on this adapter. Maybe you can find a switch that can disconnect your easy from the boiler?
mvveelen
Re: Nefit Easy™
Post by mvveelen »
There is no other switch unfortunately. I would like to disconnect the 2 wires that run to the Nefit Easy, but don't know how.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
SweetPants
Re: Nefit Easy™
mvveelen wrote: Friday 29 September 2017 19:44 There is no other switch unfortunately. I would like to disconnect the 2 wires that run to the Nefit Easy, but don't know how.
I have build my own based on ESP8266. I now switches 230v, but that could be one of the thermostat wires also. Maybe you can use the Wemos, attach a relay and flash it with EspEasy?
mvveelen
Re: Nefit Easy™
Post by mvveelen »
The Wemos, EspEasy (or Tasmota) is the easy part. What relay can I use and how can I connect it?
Going to do some research using Google again :)
SweetPants
Re: Nefit Easy™
mvveelen wrote: Friday 29 September 2017 19:54 The Wemos, EspEasy (or Tasmota) is the easy part. What relay can I use and how can I connect it?
Any normal relay will do (no solid state i think). It's only 24V. You can use http://www.ebay.com/itm/Relay-5V-Channe ... 2500451836 and directly connect it to the Wemos i think
mvveelen
Re: Nefit Easy™
Post by mvveelen »
Doesn't look too difficult. As seen in this video (not switching 22V, but the 24V in my case :)). Love the accent ;)
Just ordered the relay in your link, thanks.
SweetPants
Re: Nefit Easy™
mvveelen wrote: Friday 29 September 2017 20:09 Doesn't look too difficult. As seen in this video (not switching 22V, but the 24V in my case :)). Love the accent ;)
Be aware to use the NC (Normally Closed) contact, then if your wemos for what ever reason looses power, your thermostat stays on.
melvinc
Domoticz version: v3.8153
Re: Nefit Easy™
Post by melvinc »
Does anyone have an idea how to connect two Nefit Easy thermostats to one Domoticz instance? Can we use or specify a certain port to Nefit Easy A and anothter port for Nefit Easy B? I tried the following but only one shows in Domotcz...
#!/bin/bash
/usr/bin/easy-server --serial=************* --access-key=************************ --password=****** --host=127.0.0.1 --port= 3000 >/dev/null
/usr/bin/easy-server --serial=************* --access-key=************************ --password=****** --host=127.0.0.1 --port= 3001 >/dev/null
SweetPants
Re: Nefit Easy™
I think yes, just add a second Nefit hardware device and bind it to the second port. Just give it a try
Edit: Just tried it myself and get a second set of Nefit devices. You have to allow new devices also
melvinc
Re: Nefit Easy™
Post by melvinc »
SweetPants wrote: Wednesday 01 November 2017 18:15 I think yes, just add a second Nefit hardware device and bind it to the second port. Just give it a try
Hi SweetPants,
Strange, what did you do exactly? Just add the line and --port option in the start script? And then add the hardware with the 3001 port and you're able to select the needed components in devices? Because that is what I did and nothing shows under devices, only the old Nefit Easy that was already connected. Also allow new devices is enabled.
Thanks for your help!
SweetPants
Re: Nefit Easy™
melvinc wrote: Wednesday 01 November 2017 19:09Strange, what did you do exactly?
I start the easy instances from cron after reboot with:
@reboot /home/pi/scripts/easiest_1 > /dev/null 2>&1
@reboot /home/pi/scripts/easiest_2 > /dev/null 2>&1
The two scripts contain the startup commands but with different ports (3000 = default and --port=3001) like you mentioned. You can check if they start with ps -ef | grep easy
Add new Nefit hardware and use the second port 3001 and enable new hardware
They show up in unused devices
melvinc
Re: Nefit Easy™
Post by melvinc »
SweetPants wrote: Wednesday 01 November 2017 19:43
Hmmm I followed the guide from the Wiki, that is not the same as on your system is it? What I did is just copy the one and only line in nefiteasyhttpserver.sh and paste it below and added a --port=3000 and --port-3001 and changed the serials/accesskey and password of-course :-)
Maybe I'm lost, but really doesn't work for me over here :-)
SweetPants
Re: Nefit Easy™
But do you have two instances of the easy-server running? (ps -ef | grep easy-server)
melvinc
Re: Nefit Easy™
Post by melvinc »
SweetPants wrote: Wednesday 01 November 2017 21:44 But do you have two instances of the easy-server running? (ps -ef | grep easy-server)
uhhhh? Don't see anything recent over here... the *2.sh was some trial and error over here without the outcome I hoped for :-)
pi@DOMOTICZ:~ $ ps -ef | grep easy
pi 379 22345 0 19:00 ? 00:00:00 bash /home/pi/nefiteasyhttpserver.sh
pi 380 379 0 19:00 ? 00:00:09 node /usr/bin/easy-server --serial=************ --access-key=*********** --password=******** --host=127.0.0.1 --port=3000
pi 963 31403 0 21:47 pts/1 00:00:00 grep --color=auto easy
root 28899 22299 0 Oct31 pts/0 00:00:00 sudo nano /home/pi/nefiteasyhttpserver.sh
root 28904 28899 0 Oct31 pts/0 00:00:00 nano /home/pi/nefiteasyhttpserver.sh
root 31432 31403 0 13:20 pts/1 00:00:00 sudo nano /etc/init.d/nefiteasyhttpserver2.sh
root 31436 31432 0 13:20 pts/1 00:00:00 nano /etc/init.d/nefiteasyhttpserver2.sh
root 31437 31403 0 13:20 pts/1 00:00:00 sudo nano /etc/init.d/nefiteasyhttpserver.sh
root 31441 31437 0 13:20 pts/1 00:00:00 nano /etc/init.d/nefiteasyhttpserver.sh
root 31466 31403 0 13:23 pts/1 00:00:00 sudo nano /etc/init.d/nefiteasyhttpserver2.sh
root 31470 31466 0 13:23 pts/1 00:00:00 nano /etc/init.d/nefiteasyhttpserver2.sh
pi@DOMOTICZ:~ $
SweetPants
Re: Nefit Easy™
I see only on instance on port 3000 hence you not get the nefit hardware running on 3001. The easy-server is not daemonised so the start script stops after launching the first, that is why I start it from cron @reboot.
melvinc
Re: Nefit Easy™
Post by melvinc »
Indeed that's what I see as well, so instead of duplicating the first line of the .sh script I should duplicate the compete script like I did before? But in that case when I try to run it it's always shown as stopped.
melvinc
Re: Nefit Easy™
Post by melvinc »
melvinc wrote: Wednesday 01 November 2017 22:04 Indeed that's what I see as well, so instead of duplicating the first line of the .sh script I should duplicate the compete script like I did before? But in that case when I try to run it it's always shown as stopped.
Tried it again, and it seems to work now :D
pi@DOMOTICZ:~ $ sudo nano /home/pi/nefiteasyhttpserver.sh
pi@DOMOTICZ:~ $ sudo nano /home/pi/nefiteasyhttpserver2.sh
pi@DOMOTICZ:~ $ chmod 755 nefiteasyhttpserver.sh
pi@DOMOTICZ:~ $ chmod 755 nefiteasyhttpserver2.sh
pi@DOMOTICZ:~ $ pm2 start /home/pi/nefiteasyhttpserver2.sh
[PM2] Starting /home/pi/nefiteasyhttpserver2.sh in fork_mode (1 instance)
[PM2] Done.
│ App name │ id │ mode │ pid │ status │ restart │ uptime │ cpu │ mem │ user │ watching │
â”──────────────────────┼────┼──────┼──────┼────────┼─────────┼────────┼─────┼──────────┼──────┼──────────┤
│ nefiteasyhttpserver │ 0 │ fork │ 1005 │ online │ 694 │ 54m │ 0% │ 2.3 MB │ pi │ disabled │
│ nefiteasyhttpserver2 │ 2 │ fork │ 1225 │ online │ 0 │ 0s │ 0% │ 2.3 MB │ pi │ disabled │
Use `pm2 show <id|name>` to get more details about an app
pi@DOMOTICZ:~ $ pm2 save
[PM2] Saving current process list...
[PM2] Successfully saved in /home/pi/.pm2/dump.pm2
pi@DOMOTICZ:~ $ ps -ef | grep easy-server
pi 1006 1005 0 21:54 ? 00:00:06 node /usr/bin/easy-server --serial=********** --access-key=********** --password=********** --host=127.0.0.1 --port=3000
pi 1226 1225 2 22:49 ? 00:00:03 node /usr/bin/easy-server --serial=********** --access-key=********** --password=********** --host=127.0.0.1 --port=3001
pi 1249 1151 0 22:51 pts/0 00:00:00 grep --color=auto easy-server
pi@DOMOTICZ:~ $
I think this is okay or should I change anything to get it running after a restart?
SweetPants
Re: Nefit Easy™
melvinc wrote: Wednesday 01 November 2017 22:54 I think this is okay or should I change anything to get it running after a restart?
After a restart of what?. I do it @reboot via cron
RikkieB
Domoticz version: 4.9732
Re: Nefit Easy™
Post by RikkieB »
pepijn wrote: Saturday 05 March 2016 23:03
gizmocuz wrote:Just found it (your fast!) thanks
Apparently the 'worcester-wave-thermostat' is also from bosch
Here is the list i promised :)
  • Nefit Easy (Netherlands)
  • Junkers Control CT100 (Belgium)
  • Buderus Logamatic TC100 (Belgium)
  • E.L.M. Touch (France)
  • Worcester Wave (UK)
  • Bosch Control CT‑100 (Other)
Hi, is there NO differences between these thermostats? Hardware/Software wise?
I want to try to use nefit easy on Buderus Logamax plus gb112-29T25H/V, because nefit adapter is not available in Belgium.
Any Solutions are welcome 😀
Thx
RikkieB
Re: Nefit Easy™
Post by RikkieB »
RikkieB wrote: Monday 27 November 2017 11:16
Thx
I can confirm that the Nefit easy with Easy Connect works with a Buderus Logamax plus gb112-29T25H/V :lol:
