I've created a HTTPS certificate with letsencrypt for my domain now and it's working good when i connect to https://<my-domain>
But i always have to type https:// in front of my domain name. Is it possible to redirect to https automatically.
I searched everywhere but can't find an answer.
Thanx in advance!
BTW: Domoticz is running on an RPI.
Forward HTTP to HTTPS
Re: Forward HTTP to HTTPS
Ok, but how do i do that?
There's nothing behind port 80 btw.
Thanx!
Is all this not possible with the build-in webserver from Domoticz itself?
Electrocut
Another option would be to add "HTTP Strict Transport Security" (HSTS) header to your web server.
With this header set, if you type http://domain in your address bar, your browser will automatically switch to https://domain, without even trying to contact the http://domain server.
Sounds good. Is this possible in Domoticz?Electrocut wrote: Friday 27 October 2017 16:55 Another option would be to add "HTTP Strict Transport Security" (HSTS) header to your web server.
- gizmocuz
What you want to do could be done with NGINX as a proxy
Okay, I think I need NGINX at least. I will look at it, thank you!
essayreviews
good post.how to covert the http to https.I need the https certificate,because the https is most valuable for site.how to convert that.
