Hi!
i use a raspberry pi and aeon z-wave stick gen5 with domoticz, i want to monitor my power consumption and i was thinking of getting a Aeon Labs - Home Energy Meter / 3-fas / 0A till 60A / IP44 (Gen 5)
How does this thing work?
After i have installed the energy meter and everything is paired, should the power meter usage show up in domoticz, or do i need to do anything else with it to get it to work?
and hoe accurate is this meter?
- LouiS22
Re: Aeon Labs - Home Energy Meter
It'll show the usage data instantly, but you have to tweak the parameters according to your needs.
tjabas
Ok, so it Works good with Domoticz?
Derik
- Domoticz version: BETA
you have to check the openzwave page in the wiki..
When it is support in openzwave...
Domoticz can handle it..
When not.
And you learn the device.
You can kill your zwave network
When not.
