RFLink R48 available
433Mhz opensource Receiver & Transmitter.
Stuntteam
Post by Stuntteam »
R48: (18/10/2017)
- New Device: British Gas RC Plus Thermostat
- New Device: Drayton Digistat +2RF Thermostat
- New Device: Worcester Bosch DT10RF Thermostat
- New Device: Danfoss TP4000 Thermostat
- New Device: Vaillant VRT 340f Thermostat
- New Device: CalorMatic 340f Thermostat
- New Device: Hager Flash Thermostat
- New Device: Thermoflash Thermostat
- New Device: Piloteco Thermostat
- New Device: Sanfil Thermostat
- New Device: Monomat Thermostat
- New Device: Micromat Thermostat
- New Device: Monotron Thermostat
- New Device: Mémoprog RF Thermostat
- New Device: Calidou Plus Thermostat
- New Device: Radiafonte II Thermostat
- New Device: Bellagio II Thermostat
- New Device: Verplus Thermostat
- New Device: Palatino Thermostat
- New Device: Verlys Evolution Thermostat
- New Device: Melody Evolution Thermostat
- New Device: Millenium Triphasé Thermostat
- New Device: Sensual SAS Thermostat
- New Device: Sensual Bains Thermostat
- New Device: Athena Millenium Thermostat
- New Device: Athena Plenitude Thermostat
- New Device: Brel (and compatible) light switch
- New Device: Beurer BG64 (and possibly BF100) scales
- New Device: Falmec hoods
- Added: support for X10 Marmitec DS90/DS91 tamper switch
- Fixed: Milight color issue
- Fixed: Milight brightness issue
- Fixed: Milight RGB-CCT pairing made easier with pair/unpair commands
- Fixed: Milight CRC calculation on some of the protocol versions
- Fixed: Improved Kerui D025/D026 handling
- Fixed: Improved Mertik filtering
- Fixed: bug with Europe switchset unit numbers
- Fixed: Corrected TFA timing
- Fixed: Improved Cresta packet filtering
http://www.rflink.nl/blog2/
remb0
Re: RFLink R48 available
Post by remb0 »
great work!
a methode (credits ro roondar) to easy update from commandline. fire these commands:
sudo apt-get install python2.7 avrdude
wget https://github.com/roondar/RFLink-update/archive/master.zip
unzip master.zip
cd RFLink-update-master/
cp settings.ini.tpml settings.ini
chmod 755 update_RFLink.py
python update_RFLink.py
DutchHans
Post by DutchHans »
I am on V46 does it work there aswell?
Regards, Hans
CaesarPL
Post by CaesarPL »
DutchHans wrote: Thursday 19 October 2017 9:51 I am on V46 does it work there aswell?
This is general way of update on Raspberry, so it will work on any version.
LouiS22
Post by LouiS22 »
remb0 wrote: Wednesday 18 October 2017 19:44 great work!
unzip master.zip
Is this working with USB, or do I have to ser2net first?
CaesarPL
Post by CaesarPL »
I will be testing that today, but I think that disabling RFLink, then
avrdude -v -p atmega2560 -c stk500 -P /dev/ttyACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
and enabling again will be the same
Stuntteam
Post by Stuntteam »
Indeed you can disable/avrdude/enable but then you will need avrdude to be on your system.
Without avrdude you will need at least part of the above instructions..
In general, the update method will work with any rflink version as it is a generic way to reflash the Arduino.
CaesarPL
Post by CaesarPL »
Stuntteam wrote: Thursday 19 October 2017 11:39 Indeed you can disable/avrdude/enable but then you will need avrdude to be on your system.
Yes yes, of course. My comment was written assuming that avrdude is installed.
rleunk
Post by rleunk »
unzip master.zip
Thanks Stunteam for the update.
I have 2 RFLink's on my Raspberry Pi 3, 1 433MHz and 1 868MHz, I updated with the commands as written above, only one RFLink gets the update, can i change something in the settings so the other one get's the update to?
Your RFLink 433 hardware has idx 7 in version 47.8 on port /dev/ttyACM0
Your RFLink 868 hardware has idx 8 in version 48.4 on port /dev/ttyACM1
datzmazzie
Domoticz version: 2.3430
Post by datzmazzie »
Thank you for the update! I update my RFLink to R48.
I wonder what this means: - Fixed: Milight color issue
I have issues since the biginning of the mi-light support.
When I try to set my LED strip to for example #ff0000 the color turns green.
2017-11-21 12:58:11.562 RFLink Sending: 10;MiLightv1;f740;01;00ff;ON
2017-11-21 12:58:11.797 RFLink Sending: 10;MiLightv1;f740;01;00ff;BRIGHT
2017-11-21 12:58:12.223 (RFLink) Lighting Limitless/Applamp (RGB LED Strip)
Should this been fixed in the R48 (seems to be not) or is this another problem?
Raspberry Pi 3B, Arduino Mega, RFLink
My Blog
edwinh81
Domoticz version: 2024.4
Post by edwinh81 »
I just updated my RFlink to R48.
Now it looks like the data from my rainsensor (alecto V1) is not processed correctly anymore.
It indicated that the sensor reports 7624mm of rain today while it should be somewhere around 5mm.
I did not change anything else, just updated from R45 to R48.
Anybody who has a clue?
poudenes
Domoticz version: 3.8993
Post by poudenes »
I can't use the kelvin option. Original device from Milight Controller have Kelvin option. The RFlink device pair the kelvin is gone in device.
Also Brightness you can't change using dzVents. It work with combination with Milight Controller
poudenes
Post by poudenes »
I see a difference between the commands that sends by Milight App (iOS) and what RFlink receives and the commands that been send by Domoticz for brightness
MiLIght App: 10;MiLightv1;20f504;01;c0094;BRIGHT - c0094 was brightness level
Domoticz: 10;MiLightv1;20f504;01;00fc;BRIGHT - 00fc was brightness level
Both are different. Can this be the problem why Brightness is not working?
