Domoticz on OpenWRT
Re: Domoticz on OpenWRT
Plugged Aeon Labs Aeotec Z-Wave Z-Stick (ZW090). Seems to be recognized by Omega2+ by adding /dev/ttyACM0 but can't add it in Domoticz Hardware. Log says "Openzwave driver failed!".
Any suggestion to track where the issue is (Onion Omega2+ is based on LEDE OS)?
Here is in more details what I get :
1. plugin ZW090 usb stick :
OS recognize the USB device
2. Adding hardware in
3. Domoticz log :
4. lsusb informations :
I did an opkg install openzwave but changed nothing.
[ 3090.322796] usb 2-1: new full-speed USB device number 2 using ohci-platform
[ 3090.546582] cdc_acm 2-1:1.0: ttyACM0: USB ACM device
3. Domoticz log :
2017-09-06 19:59:00.044 Domoticz V3.8153 (c)2012-2016 GizMoCuz
2017-09-06 19:59:00.046 Build Hash: b97777b, Date: 2016-11-09 06:33:42
2017-09-06 19:59:00.049 Startup Path: /usr/bin/
2017-09-06 19:59:00.942 Active notification Subsystems: gcm, http (2/12)
2017-09-06 19:59:01.056 WebServer(HTTP) started on address: :: with port 8080
2017-09-06 19:59:01.101 Proxymanager started.
2017-09-06 19:59:01.267 Starting shared server on: :::6144
2017-09-06 19:59:01.271 TCPServer: shared server started...
2017-09-06 19:59:01.273 RxQueue: queue worker started...
2017-09-06 19:59:03.628 EventSystem: reset all events...
2017-09-06 19:59:03.631 EventSystem: reset all device statuses...
2017-09-06 19:59:03.646 EventSystem: Started
2017-09-06 20:48:04.660 Incoming connection from: 192.168.2.219
2017-09-06 20:50:45.078 OpenZWave: using config in: /usr/share/domoticz/openzwave/
2017-09-06 20:50:45.153 OpenZWave: Starting...
2017-09-06 20:50:45.154 OpenZWave: Version: 1.4-164-g770378b
2017-09-06 20:51:05.249 Error: OpenZWave: Driver Failed!!
root@Omega2p:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0658:0200 Sigma Designs, Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
root@Omega2p:~# lsusb -s2:2 -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0658 Sigma Designs, Inc.
idProduct 0x0200
bcdDevice 0.00
iManufacturer 0
iProduct 0
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 67
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC Call Management:
bmCapabilities 0x00
bDataInterface 1
CDC ACM:
bmCapabilities 0x00
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0020 1x 32 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
- Domoticz version: V4.10717
Hi timeless,
I'm trying to compile domoticz on recent lede trunk, but I get following error:
I guess the reason is above include path because the correct path of boost 1.65.1 is in a subdir boost !?
But I can't see how to update the lede/Makefile correctly ?
lede domoticz package Makefile version is:
CMake Error at [...]/lede/source/staging_dir/host/share/cmake-3.8/Modules/FindBoost.cmake:1842 (message):
Unable to find the requested Boost libraries.
Boost version: 1.65.1
Boost include path:
[...]/lede/source/staging_dir/target-arm_arm1176jzf-s+vfp_musl_eabi/usr/include
Could not find the following Boost libraries:
boost_thread
boost_date_time
boost_system
No Boost libraries were found. You may need to set BOOST_LIBRARYDIR to the
directory containing Boost libraries or BOOST_ROOT to the location of
[...]/lede/source/staging_dir/target-arm_arm1176jzf-s+vfp_musl_eabi/usr/include/boost
PKG_NAME:=domoticz
PKG_VERSION_MAJOR:=3
PKG_VERSION_PATCH:=8153
PKG_VERSION:=$(PKG_VERSION_MAJOR).$(PKG_VERSION_PATCH)
PKG_RELEASE:=3
- Domoticz version: 2020.2
Have you figure this one out?HM31 wrote: ↑Wednesday 30 August 2017 14:55 Plugged Aeon Labs Aeotec Z-Wave Z-Stick (ZW090). Seems to be recognized by Omega2+ by adding /dev/ttyACM0 but can't add it in Domoticz Hardware. Log says "Openzwave driver failed!".
Regarding your issue - maybe it is matter of rights for /dev/ttyACM0. I had simiar issue with MySensors conected via serial port.
Or change to run domoticz as root or:
chmod 777 /dev/ttyACM0
Hi, Regarding issue with Boost library. I tried "amke clean" and many other option (like diffconf etc). The only way was to clean clone git repository and choose platform and packets from beginning. I have to also choose python3 as module and boost python as module.
I installed the latest LEDE development snapshot on a Linksys WRT1200AC.
Installation worked fine and enough space to install domoticz.
Installation of domoticz works fine also. Thanks for this.
However I connected the RFX433 transceiver on the USB port 1: it is not recognized in the domoticz configuration page.
When I do an "lsusb" in the console , I get:
root@wifibox:~# lsusb
Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
So the RFX433 is well connected.
I already installed domoticz on a raspberry PI3 with the RFX433 and it is working well without any additional package installation.
For LEDE/OpenWRT, is there any additional package required ?
Thanks for the help.
Following above message, I checked if FTDI serial package was present. No it was not. I installed "kmod-usb-serial-ftdi". Now RFX433 is recognized and /dev/ttyUSB0 appears in the domoticz hardware page for FRX433 serial port selection.
However it seems not enough for working properly:
Domoticz log :
2017-12-10 20:21:55.258 Error: RFXCOM: Error opening serial port!
2017-12-10 20:21:56.258 RFXCOM: retrying in 30 seconds...
2017-12-10 20:22:25.260 Error: RFXCOM: Error opening serial port!
2017-12-10 20:22:26.261 RFXCOM: retrying in 30 seconds...
2017-12-10 20:22:55.262 Error: RFXCOM: Error opening serial port!
2017-12-10 20:22:56.262 RFXCOM: retrying in 30 seconds...
Any idea ?
Domoticz log :
Any idea ?
Many thanks, I didn't think about this. Meantime I install Domoticz on a Synology NAS that served for my cameras. I'll test it when I'll have some free times.
May be rocknsalsa has the same issue with /dev/ttyUSB0
Hello everybody!
I have installed OpenWRT on my router ASUS RT-AC58U and domoticz. Working fine, but don't see Aqara wireless switches (1 and 2 keys, 4ps). At the same time at the windows domoticz that switches work fine.
Tell me please how can i solve this problem? Thank you!
