Version: 3.8153
Platform: Raspberry Pi 3
Plugin/Hardware: Razberry 2 z-wave
Description:
I'm running a custom website with a frontend for switches in Domoticz based on JSON. I've gotten the code from the three youtube companion articles found here: https://fabuloushomeautomation.wordpress.com/
I used to have the website running on Apache webserver on Raspberry Pi, and everything worked perfectly until I updated Domoticz to a new version. After this, it has only worked one way (if something changes in Domoticz, it does so in my website also --- but if I press a button on my website, nothing happens).
I know that there's nothing wrong with the coding, since it works perfectly when I upload the site to within Domoticz own webserver.
Domoticz own webserver, however, doesn't have Php-functionality, which I need for other purposes.
That leaves me with two possible ways of solving this:
1.) Add Php-functionality to Domoticz own (proprietary?) webserver
2.) Somehow solve the issue that JSON-commands only works one way outside of Domoticz webserver.
I'm at a loss to know how to go about this
Plz help.
JSON not working properly outside Domoticz webserver / No Php support in Domoticz own webserver
perrydomoticz
holdemblow
- Domoticz version: 3.8153
Re: JSON not working properly outside Domoticz webserver / No Php support in Domoticz own webserver
After updating Domoticz it's kinda ignorant assuming the script should still be okay as it worked before..
Probably the call or arguments to switch on/off have changed.
Probably wise to check the logs of your php scripts as the information you're currently providing isn't helping much
- domoticz rpi
- 1X RFXtrx433e USB 433.92MHz Transceiver
- 3x kaku plugs
- 3x Action kaku-like plugs
- 1x kaku inbouw
- 1x kak deurbel
- 3x Flamingo FA21RF
- 1 aeon labs z-wave plus
- neocoolcam NAS-WR01ZE smart stekker
- 3x kaku plugs
- 1x kaku inbouw
- 1x kak deurbel
jannl
- Domoticz version: 2025.5.x
Starting a one point, the password for switches needs to be in the json call. This once was in a Domoticz update.
Do you use protected switches?
