I have a Synology NAS working with the RFLink (R47).
I am am controlling Somfy blinds (1002295A Tilt&Lift 25 RTS Central)
I found that the control is working best when I use RTSLONGTX.
However when I use this option I get "Error: RFLink: TX time out..." because the command takes really long time to respond.
So I would like to know how this option works?
Is the command repeated many times or what happens ?
Also is it be possible to adjust the time it is sending the command ?
I know my blinds do not need the command for that long because they er finished moving before the command finishes.
RTSLONGTX explanation
- Stuntteam
Re: RTSLONGTX explanation
It is experimental and not compatible with Domoticz.
