Group on/off
febalci
Group on/off
I am using the Group Switch in Scenes for all the rollershutters. If i press down off, all shutters close and for on all shutters open. What i wonder is, is there a status check mechanism in Groups; like when pressing "Off" does the Group switch send all shutters an "Off" message whether they are open or closed, or only the ones which are already or partially open? I do not want to create a zwave network traffic for all the switches, or should i use a script which checks the status of the shutters, instead of using a group?
febalci
Re: Group on/off
Let me answer my own question; just found out that Group switches send all members of the group on/off messages, whether they are on or off. So instead of using group switch i used an "if" status check one by one and then send off messages accordingly.
Re: Group on/off
Are you using the Fibaro FGRM222 ?
I have 12 of them and when I put them in a group I could turn it "off" (so everything closed) but I wasn't able to press the button again to make them go "on".
So, my group only allowed the closing...
To resolve this I created 2 scenes. 1 for close and 1 for open.
My fibaro's are configured as blinds percentage inverted. Yours too ?
- emme
- Domoticz version: latest
Re: Group on/off
do not worry about flooding the zWave network, you will never mess it!
(well.. maybe only if you start playing with pollings
...by my opinion, you take much more server resources and CPU load with a script that query the device and issue the off command if needed, than issue the command by a group
"We always done this way"
- emme
Re: Group on/off
that's not good...Maes wrote: Friday 20 October 2017 9:49 Are you using the Fibaro FGRM222 ?
I have a group of 6 and they go on and off correctly.....
can you post a screenshot of you group configuration?
Re: Group on/off
Do you also have them configured as blinds percentage inverted?
This is a screenshot of my scene. I don't have the group anymore.
febalci
Re: Group on/off
I use Qubino ZMNCHD flush shutter modules, 11 of them. They are all in "Blinds Inverted Percentage". Group On and Off works as expected, no problems there. However when i make a "Group Off" Request, Imperihome loses status. There's no problem with the "Group On" function.febalci wrote: Friday 20 October 2017 9:38 Let me answer my own question; just found out that Group switches send all members of the group on/off messages, whether they are on or off. So instead of using group switch i used an "if" status check one by one and then send off messages accordingly.
