Hello.
I have a question about saveoverlayfs which is explained here. https://www.domoticz.com/wiki/Setting_u ... spberry_Pi
I'm running 2017-09-07-raspbian-stretch-lite.img on Raspberry Pi 3, and followed the explanation on the above page.
(So far, I was using your technique with Raspbian Wheezy and working fine. However I'm confused because I'm not familiar with systemd in Jessie and Stretch.)
After set-up of the saveoverlayfs, it looks working mostly, but I found a severe problem. The phenomenon is, while repeating log-in for the account 'pi' and "sudo shutdown -r now", sometime the directory /home gets lost. After debugging the script /etc/init.d/saveoverlayfs, I found its reason.
In the loop below, even the directory (or mount point) "/home" actually exists in the variable OVERLAYFS,
for DIR in ${OVERLAYFS}
do
when the command rsync tries to copy the file in the /home, the directory /home looks already unmounted at the time by some reason.
Because /home is unmounted, rsync considers that the directory is empty and /home_stage also becomes empty, and the contents of /home_org gets lost. (rsync removes the contents of the directory as shown below.)
saveoverlays sync /home to /home_org with options -avH --delete-after --inplace
--no-whole-file --exclude *.leases at Sat 14 Oct 04:53:23 UTC 2017
---- Staging to /home_stage ------
building file list ... done
deleting pi/.wget-hsts
deleting pi/.profile
deleting pi/.bashrc
deleting pi/.bash_logout
deleting pi/.bash_history
deleting pi/
sent 43 bytes received 18 bytes 122.00 bytes/sec
total size is 0 speedup is 0.00
---- Copy to /home_org ------
deleting pi/.bashrc
deleting pi/
saveoverlays sync /home to /home_org ended at Sat 14 Oct 04:53:23 UTC 2017
I checked the beginning part of the script, and I found the following declaration.
# Required-Stop: umountfs
I guess, it means that unmount of /home needs to come after the saveoverlayfs. However, when rsync is trying to sync files, there looks a chance that the directory /home was already unmounted.
I don't know why this occur because I'm afraid that I'm not familiar with systemd behavior.
Any suggestion would be highly appreciated.
Regards,
Atsushi
saveoverlays sometimes fails to sync when rebooting Raspbian Stretch
