I made this dzVent (I copied only the 'execute' part):
execute = function(domoticz, roomSwitch)
if (roomSwitch.state == 'On') then
domoticz.log('---------------------------------- Switch 46 has been turned on')
domoticz.log(domoticz.variables('BurstSwitch').value)
if (domoticz.variables('BurstSwitch').value > 0) then
domoticz.log('---------------------------------- begin minus 1 loop')
currentValue = domoticz.variables('BurstSwitch').value
domoticz.log('currentValue is:')
domoticz.log(currentValue)
newValue = currentValue - 1
domoticz.log('newValue is:')
domoticz.log(newValue)
domoticz.variables('BurstSwitch').set(newValue)
domoticz.devices(46).switchOn()
domoticz.log('---------------------------------- end of minus 1 loop')
domoticz.devices(46).switchOff().afterSec(5)
if (domoticz.variables('BurstSwitch').value == 0) then
domoticz.variables('BurstSwitch').set('5')
domoticz.log('---------------------------------- reset to 5')
Intended behaviour: if a device is turned on, Domoticz will send 5 on-commands to ensure the signal is received (in general, my device might miss one or two on-commands, but never 5 in a row).
Observed behaviour: the variable BurstSwitch is sometimes stored correctly (by my calll domoticz.variables('BurstSwitch').set(newValue)), but not always.
This is what my log looks like:
2017-10-09 20:00:04.259 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:04.277 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:04.405 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:04.405 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:04.405 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:04.406 dzVents: Info: 5
2017-10-09 20:00:04.406 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:04.406 dzVents: Info: currentValue is:
2017-10-09 20:00:04.406 dzVents: Info: newValue is:
2017-10-09 20:00:04.406 dzVents: Info: 4
2017-10-09 20:00:04.407 dzVents: Info: 5
2017-10-09 20:00:04.407 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:04.407 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:04.407 EventSystem: Fetching url...
2017-10-09 20:00:04.409 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:04.425 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:04.653 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:04.653 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:04.653 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:04.654 dzVents: Info: 4
2017-10-09 20:00:04.654 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:04.654 dzVents: Info: currentValue is:
2017-10-09 20:00:04.654 dzVents: Info: newValue is:
2017-10-09 20:00:04.654 dzVents: Info: 3
2017-10-09 20:00:04.654 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:04.655 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:04.655 EventSystem: Fetching url...
2017-10-09 20:00:04.656 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:04.673 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:04.900 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:04.900 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:04.900 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:04.901 dzVents: Info: 4
2017-10-09 20:00:04.901 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:04.901 dzVents: Info: currentValue is:
2017-10-09 20:00:04.901 dzVents: Info: newValue is:
2017-10-09 20:00:04.901 dzVents: Info: 3
2017-10-09 20:00:04.901 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:04.901 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:04.902 EventSystem: Fetching url...
2017-10-09 20:00:04.903 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:04.920 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:05.149 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:05.150 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:05.150 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:05.150 dzVents: Info: 3
2017-10-09 20:00:05.150 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:05.151 dzVents: Info: currentValue is:
2017-10-09 20:00:05.151 dzVents: Info: 3
2017-10-09 20:00:05.151 dzVents: Info: newValue is:
2017-10-09 20:00:05.151 dzVents: Info: 2
2017-10-09 20:00:05.151 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:05.151 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:05.151 EventSystem: Fetching url...
2017-10-09 20:00:05.153 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:05.171 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:05.401 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:05.402 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:05.402 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:05.402 dzVents: Info: 3
2017-10-09 20:00:05.402 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:05.402 dzVents: Info: currentValue is:
2017-10-09 20:00:05.403 dzVents: Info: newValue is:
2017-10-09 20:00:05.403 dzVents: Info: 2
2017-10-09 20:00:05.403 dzVents: Info: 3
2017-10-09 20:00:05.403 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:05.403 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:05.403 EventSystem: Fetching url...
2017-10-09 20:00:05.405 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:05.423 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:06.160 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:06.168 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:06.168 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:06.169 dzVents: Info: 1
2017-10-09 20:00:06.169 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:06.169 dzVents: Info: currentValue is:
2017-10-09 20:00:06.169 dzVents: Info: newValue is:
2017-10-09 20:00:06.169 dzVents: Info: 0
2017-10-09 20:00:06.169 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:06.170 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:06.170 EventSystem: Fetching url...
2017-10-09 20:00:06.172 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:06.190 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:06.420 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:06.421 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:06.421 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:06.421 dzVents: Info: 1
2017-10-09 20:00:06.421 dzVents: Info: ---------------------------------- begin minus 1 loop
2017-10-09 20:00:06.421 dzVents: Info: currentValue is:
2017-10-09 20:00:06.421 dzVents: Info: newValue is:
2017-10-09 20:00:06.422 dzVents: Info: 0
2017-10-09 20:00:06.422 dzVents: Info: 1
2017-10-09 20:00:06.422 dzVents: Info: ---------------------------------- end of minus 1 loop
2017-10-09 20:00:06.422 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:06.422 EventSystem: Fetching url...
2017-10-09 20:00:06.424 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:06.442 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:06.673 dzVents: Info: Handling events for: "A7", value: "On"
2017-10-09 20:00:06.673 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:06.673 dzVents: Info: ---------------------------------- Switch 46 has been turned on
2017-10-09 20:00:06.674 dzVents: Info: 0
2017-10-09 20:00:06.674 dzVents: Info: ---------------------------------- reset to 5
2017-10-09 20:00:06.674 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:06.675 EventSystem: Fetching url...
2017-10-09 20:00:06.676 EventSystem: Script event triggered: /home/pi/domoticz/scripts/dzVents/runtime/dzVents.lua
2017-10-09 20:00:06.693 (RFXCOM zender) Lighting 1 (A7)
2017-10-09 20:00:11.841 dzVents: Info: Handling events for: "A7", value: "Off"
2017-10-09 20:00:11.841 dzVents: Info: ------ Start internal script: dztest: Device: "A7 (RFXCOM zender)", Index: 46
2017-10-09 20:00:11.841 dzVents: Info: ------ Finished dztest
2017-10-09 20:00:06.421 dzVents: Info: ---------------------------------- Switch 46 has been turned on >>>> general note that the script has started
2017-10-09 20:00:06.421 dzVents: Info: 1 >>>> current value of BurstSwitch
2017-10-09 20:00:06.422 dzVents: Info: 0 >>>> current value of newValue
2017-10-09 20:00:06.422 dzVents: Info: 1 >>>> current value of BurstSwitch (expected: 0)
