Hello all,
ich have the Problem that I could not install the Domoticz package on my synology DS712+.
The package will not include on my syno. After downloading and unzipping I miss the spk File.
So i could not install the Package on my syno.
Where is my mistake?
with best wishes
knownuser
P.S.: sorry for my bad Englisch. Ist only School english.
Edit. Change wrong spz aginst right spk
Installation on Synology712+
Re: Installation on Synology712+
Instead of dealing with zip file you can use jadahl's Synology packages. Add the url to Synology package sources, refer:
http://www.domoticz.com/forum/viewtopic ... ge#p153156
Hello Febalci,
thank You for your answer.
This is my Problem. When I make the download i can only download a *.tar file. When I unzipp this file, I cant see a spk file that the package Manager from synology will accept. I get always the message unaceptable Format ("ungültiges dateiformat" in german).
I try downloading and unzip on win 10 and unzip with 7-zip and with total commander, nothing helps. I never see the needed spk file.
Downloding on my syno and unzip there with total commander was the same ending. I dont find the spk.
where is my mistake?
Thank You
with greetings
Thank You
with greetings
Get the domoticz .spk downloads from http://www.jadahl.com/
ist the same Problem.
download from jadahl, open my synology Folder, and downlod the file as tar.
unzip the file with total commander, unzip the package that is included into a different folder, and after the second unzip nowhere i can find an spk file that will the package Manager accept.
Do not un tar it. Rename the file extension to ".spk". In jadahl web site every file is already.spk not.tar. Or download as.spk directly. How do you download? Which command or application?
Hello
I download it with Microsoft Edge. Rename will Change the file and it will accept from Package Manager. but the Package Manager will not accept with the sign not supported file Format. I try to download with Firefox or opera. Thank You for help me.
It works.
downloaded with Firefox and i get my *.spk File.
MS Edge changes the file and this make ist unacceptable for the Syno.
Thank You for helping.
Oliver
It works.
Oliver
