Turn of dummy switch if no motion after 30 min.
thorbj
Post by thorbj »
Hi, how can i get this script to turn off HouseSw, only if any of the other switches is off, and have not been turned on again within 30 minutes?
Also the notification gets sendt immediately, I wan't it to wait until the HouseSw is off.
    active = true,
        devices = {'Bevegelse Stue'},
		devices = {'Bevegelse Gang'},
		devices = {'Test'},
        -- your script logic goes here, something like this:
		local HouseSw = domoticz.devices('Bevegelse i Huset')
		local LvgrmSw = domoticz.devices('Bevegelse Stue')
		local HallSw = domoticz.devices('Bevegelse Gang')
		local TestSw = domoticz.devices('Test')
        if (HouseSw.state == 'Off') and ((TestSw.state == 'On') or (LvgrmSw.state == 'On') or (HallSw.state == 'On')) then
            HouseSw.switchOn()
            domoticz.notify('Bevegelse', 'Noen beveger seg i huset.', domoticz.PRIORITY_LOW)
            domoticz.log('Noen beveger seg i huset.')
			elseif (HouseSw.state == 'On') and (TestSw.state == 'Off') and (LvgrmSw.state == 'Off') and (HallSw.state == 'Off') then
			HouseSw.switchOff().afterMin(30)
			domoticz.notify('Ingen bevegelse', 'Ingen bevegelse i huset.', domoticz.PRIORITY_LOW)
			domoticz.log('Ingen bevegelse i huset.')
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
emme
Domoticz version: latest
Re: Turn of dummy switch if no motion after 30 min.
Post by emme »
by my understanding you cannot use a device trigger since your requirement is that... none touch them :P
so I convert the script to a time (every minute) event
check if this can work for you
    active = true,
    on = { timer = {'every minute'}, },
    execute = function(domoticz)
		local timeMinPass = 30    -- Minutes to trigger
		local timePassed = false   -- this is a flag to ensure time of 30 mins has passed
		if (LvgrmSw.lastUpdate.minutesAgo >= timeMinPass and HallSw.lastUpdate.minutesAgo >= timeMinPass and TestSw.lastUpdate.minutesAgo >= timeMinPass) and (LvgrmSw.state == 'Off' and HallSw.state == 'Off' and TestSw.state == 'Off') and HouseSw.state == 'On' then
			HouseSw.switchOff()
"We always done this way"
thorbj
Post by thorbj »
Thank you! That solved the problem :)
