nighttime not working
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
In Domoticz i have my location so have a sunset and sunrise time in dashboard.
have this dzEvent script but it does not work its also running in daytime.
Can someone assist me?
    active = true,
		timer = {'at nighttime'},
        devices = {'Keuken Sensor'}
-- ALWAYS NIGHTTIME ONLY --
-- KITCHEN LIGHT OFF WHEN GONNA SLEEP
    if
    domoticz.devices('Full Handmatige Modus').state == 'Off' and
    domoticz.devices('Scene Goodnight').state == 'On' and
    domoticz.devices('Keuken Sensor').state == 'Off' and
    domoticz.devices('Kookplaat').state == 'On'
    then
        domoticz.devices('Kookplaat').switchOff().afterSec(3)
        domoticz.log('--==<[GOODNIGHT AAN KEUKEN LICHT UIT]>==--', domoticz.LOG_FORCE)
-- KITCHEN LIGHT ON WHEN KODI IS OFF
    elseif
    domoticz.devices('Keuken Sensor').state == 'On' and
    domoticz.devices('Kodi').state == 'Off' and
    domoticz.devices('Kookplaat').state == 'Off'
    then
        domoticz.devices('Kookplaat').switchOn().afterSec(1)
        domoticz.log('--==<[KEUKEN SENSOR AAN KEUKEN LICHT AAN]>==--', domoticz.LOG_FORCE)
-- KITCHEN LIGHT OFF WHEN KODI IS OFF
    elseif
    domoticz.devices('Kookplaat').state == 'On' and
    then
        domoticz.devices('Kookplaat').switchOff().afterSec(1)
        domoticz.log('--==<[KEUKEN SENSOR UIT KEUKEN LICHT UIT]>==--', domoticz.LOG_FORCE)
leby
Re: nighttime not working
Post by leby »
Think it's because you also have
as trigger, the script will trigger on change on this sensor if I have understood it correctly.
if you change to
    active = true,
    if
    then
    elseif
    then
    elseif
    then
it should only trigger at night..
/lennart
dannybloe
Post by dannybloe »
You can restrict the device trigger to a time period as well:
devices={ ['Keuken sensor'] ={'at nighttime'}]
poudenes
Post by poudenes »
Thanks both for the info.
So both are possible. 1 The whole execute at nighttime or specific on a device. Sounds interesting. Because i can combine some dzevent script now together.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
