two out of four crontab jobs don't run
curious
Post by curious »
I check the presence of four phones every ten minutes.
This are the lines in my crontab
name1 phone
*/10 * * * * /home/pi/domoticz/scripts/check_device_online.py 10.0.0.13 461 10 120
#name2 phone
*/10 * * * * /home/pi/domoticz/scripts/check_device_online.py 10.0.0.6 462 10 120
#name3 phone
*/10 * * * * /home/pi/domoticz/scripts/check_device_online.py 10.0.0.18 455 10 120
#name4 phone
*/10 * * * * /home/pi/domoticz/scripts/check_device_online.py 10.0.0.24 463 10 120
What's odd: for ip ...6 and ...18 a new pid is created for ...13 and 24 no new files are created.
When I run the lines manually I do get a new file
Some one any idea why this can happen ?
By the way : The new created pid have no content. Is that correct ?
Dunkan
Domoticz version: V3.5877
Re: two out of four crontab jobs don't run
Post by Dunkan »
I've just implemented this program to check for the presence of 4 phones in the house. The program loops within itself (which is what the 3rd arg is for). The crontab entries are to ensure it's restarted in case it stops for any reason. Within the program you can specify whether you want to use pid (recommended) or ps to check for tasks already running for the specified IP address. Rebooting the PC is a clean way to restart everything, or use the following to check for running tasks and kill them
ps aux | grep check
I've altered the code to use both ping & arping as either by themselves was oddly not reliable for my LAN. I've also added logging, so I can tail the log file to see what's happening.
the pid file is just an empty file to show that the process is working, I think in theory is should hold the pid number which would allow you to see which task to kill if you wanted to restart the task.
To check the program you should comment out your 4 cron entries, and reboot. remove any pid files, then open 4 terminals and run the 4 tasks. You don't say what h/w or OS you are using.
curious
Post by curious »
I am running Domoticz on a Raspberry 2
When I run the 4 cron entries manually they work fine and I get 4 pid's.
When I try to change the cron with crontab -e next message appears after saving:
crontab : installing new crontab
/var/spool/cron/:mkstemp:Permission denied
crontab: edits left in /tmp/crontab.zFBpOK/crontab
So it looks like changes are saved in a temporary folder.
So I changed /var/spool/cron/pi with an editor. But they still don't run
Top of the edited file has the following lines :
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (/tmp/crontab.eaYF7K/crontab installed on Sat Jun 24 14:50:26 2017)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
# Edit this file to introduce tasks to be run by cron.
So: how do I edit the master and reinstall it ?
