All, thanks
I propose now the plugin. I tested it and I had no problem with
- Capture.PNG (50 KiB) Viewed 1459 times
The plugin is usefull to retrieve data from url. depending of the result of the response (String to find for On update / String to find for Off update:), the plugin set a switch on or off in domoticz
I use it to retreive the state of the output of two cameras (DCS 2210 & DCS2230) :
I set up event in each cam to put the output to ON during 8 second when a movement is detected.
So the plugin is set up to retrieve the state of the cams each 4 seconds by retrieving the output state of cam with the following url
http://IPADRESS/config/io.cgi
# PirCamChecker
# Author: TiXav, Sept 2017
# For My DLINK DCS2210 or DCS 2230
# I set the outpout of the camera On during 8 seconds when the cam detects someone
# So I set the Mode1 to 4 seconds to be sure the plugin catch all the detections
<plugin key="PirCamChecker" name="PirCamChecker" author="TiXav" version="1.0.0" externallink="">
<params>
<param field="Address" label="IP Address" width="200px" required="true" default=""/>
<param field="Username" label="Username" width="200px" required="true" default=""/>
<param field="Password" label="Password" width="200px" required="true" default=""/>
<param field="Mode2" label="String to find for On update" width="200px" required="true" default=""/>
<param field="Mode3" label="String to find for Off update" width="200px" required="true" default=""/>
<param field="Mode1" label="Check Interval(seconds)" width="75px" required="true" default="4"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import hmac
import hashlib
import time
import urllib
import urllib.request
import urllib.error
#from urllib2 import urlopen
from datetime import datetime, timedelta
class BasePlugin:
enabled = False
pluginState = "Not Ready"
sessionCookie = ""
privateKey = b""
socketOn = "FALSE"
def __init__(self):
self.debug = False
self.error = False
self.nextpoll = datetime.now()
self.pollinterval = 60 #Time in seconds between two polls
return
def onStart(self):
Domoticz.Debug("onStart called")
self.pollinterval = int(Parameters["Mode1"]) #Time in seconds between two polls
if Parameters["Mode6"] == 'Debug':
self.debug = True
Domoticz.Debugging(1)
DumpConfigToLog()
else:
Domoticz.Debugging(0)
# create the mandatory child device if it does not yet exist
if 1 not in Devices:
Domoticz.Device(Name="PIR_CAM", Unit=1, TypeName="Switch").Create()
Domoticz.Log("Device created.")
url = Parameters["Address"]
ToFindOn=Parameters["Mode2"]
ToFindOff=Parameters["Mode3"]
#Create a password manager to connect to the camera
password_mgr = urllib.request.HTTPPasswordMgrWithDefaultRealm()
# Add the username and password.
password_mgr.add_password(None, url, Parameters["Username"], Parameters["Password"])
handler = urllib.request.HTTPBasicAuthHandler(password_mgr)
# create "opener" (OpenerDirector instance)
opener = urllib.request.build_opener(handler)
# use the opener to fetch a URL
f=opener.open(url)
aa=f.read()
VV = str(aa,'utf-8')
VV.join(VV.splitlines())
Domoticz.Debug(""+VV)
PosOn=VV.find(ToFindOn)
PosOff=VV.find(ToFindOn)
Domoticz.Debug("PosOn="+str(PosOn)+"/PosOff="+str(PosOff))
if PosOn>-1:
UpdateDevice(1,1,"On")
if PosOff>-1:
UpdateDevice(1,0,"Off")
# Install the opener. Now all calls to urllib.request.urlopen use our opener.
urllib.request.install_opener(opener)
aa = urllib.request.urlopen(url).read()
Domoticz.Heartbeat(int(Parameters["Mode1"]))
def onStop(self):
Domoticz.Log("Plugin is stopping.")
def onCommand(self, Unit, Command, Level, Hue):
if Command=="On":
Devices[1].Update(1, "1")
if Command=="Off":
Devices[1].Update(0,"0")
Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
return
def onHeartbeat(self):
Domoticz.Debug("onHeartbeat called")
now = datetime.now()
if now >= self.nextpoll:
self.nextpoll = now + timedelta(seconds=self.pollinterval)
try:
response = urllib.request.urlopen(url, timeout = 30).read()
except urllib.error.HTTPError as err1:
Domoticz.Error("HTTP Request error: " + str(err1) + " URL: " + url)
return
else:
VV = str(response,'utf-8')
PosOff=VV.find(ToFindOff)
if PosOn>-1:
if PosOff>-1:
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
return
def UpdateDevice(Unit, nValue, sValue):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if (Unit in Devices):
if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
Devices[Unit].Update(nValue, str(sValue))
Domoticz.Log("Update "+"' ("+Devices[Unit].Name+") "+":'"+str(sValue))
return
# Parse an int and return None if no int is given
def parseIntValue(s):
try:
return int(s)
except:
return None
