PM me you apple id email, then ill add you to the beta list
Domoticz App
- galadril
- Domoticz version: latest
Re: Domoticz App
- galadril
Re: Domoticz App
Happy that we solved it!
Re: Domoticz App
Re: Domoticz App
I've got the same problem. I've also bought the premium version but it's not activated.
I've tried a several times to buy and restore. It gives the same error: could not restore your premium account
I've also tried removing the app and reinstall it again.
Is there something else I can try?
- galadril
Re: Domoticz App
Can you completely remove the current app, and install the latest (there is a update today)BennyV wrote: ↑Friday 29 September 2017 14:24 I've got the same problem. I've also bought the premium version but it's not activated.
Hope that it solves your issue..
- Domoticz version: 4.11670
Re: Domoticz App
I deleted the app and downloaded the newest version. but no luck, still getting the 'Could not restore your premium account'.
When I click on BUY again, it tells me that I already buyed the app. I tried it just 5 minutes ago.
I installed the new IOS, maybe thats the problem.
Re: Domoticz App
Something does not work. In addition to the ability to change the theme to dark, I do not see any additional options such as geofencing or the ability to add a widget to the home screen.
Domoticz ver. 3.8153
Re: Domoticz App
I've tried, but it did not work. The steps I've done:galadril wrote: ↑Monday 09 October 2017 9:48Can you completely remove the current app, and install the latest (there is a update today)BennyV wrote: ↑Friday 29 September 2017 14:24 I've got the same problem. I've also bought the premium version but it's not activated.
1. Remove current app
2. Reboot iphone
3. Install latest app
4. Tried restore premium
5. Tried buying again
> still same errors
- galadril
Re: Domoticz App
Srry but im at an API summit in sweden at the moment.BennyV wrote:I've tried, but it did not work. The steps I've done:galadril wrote: ↑Monday 09 October 2017 9:48Can you completely remove the current app, and install the latest (there is a update today)BennyV wrote: ↑Friday 29 September 2017 14:24 I've got the same problem. I've also bought the premium version but it's not activated.
2. Reboot iphone
> still same errors
Ill contact you in two days!
Verstuurd vanaf mijn SM-T713 met Tapatalk
Re: Domoticz App
I have bought the app 2 months ago,
Butt I can't restore my account
How can I change this
Galadril can you help me .?
- Target OS: OS X
Re: Domoticz App
Great app! Works perfectly fine with Domoticz, Klik-aan-Klik-uit, Xioami gateway/switches/sensor!
Re: Domoticz App
Hey
A super app nice that it is.
I bought him only bought a new count, I also bought the app again and if I want to have him on multiple aparates
Who wants to help me
thank you in advance.
Re: Domoticz App
If you have multiple devices on the same account and bought the app one time, you can use the app on all the device linked to the account. I'm running the app on both a Nexus 7 tablet and my mobile phone
Re: Domoticz App
On my IPAD the Domoticz app does not show the timer info for switches
Instead of the time it displays: "true | Every day"
The app for Android works correctly. It dispalys f.i. : 18:45 | Every day
can somebody help ??
Also in the latest release of the App the timer info for switches is not displayed correctly.
Is this a known issue ?
- galadril
Re: Domoticz App
I'm progressing in a next new feature, Speech Controls:
You'll be able to register a phrase and connect it to a switch.
Next time you use that phrase it toggles the switch
See screenshots at the bottom of this github commit:
https://github.com/domoticz/domoticz-xa ... 3dd65ec8ee
Re: Domoticz App
I still have “error network” after few seconds..
Inviato dal mio iPad utilizzando Tapatalk
- galadril
Re: Domoticz App
marcotrumpet wrote: ↑Thursday 26 October 2017 12:24 I still have “error network” after few seconds..
Then your connection settings are not correct
Re: Domoticz App
So with incorrect settings works for a little bit than stop working?
Inviato dal mio iPhone utilizzando Tapatalk
- Domoticz version: 3.5877
Re: Domoticz App
What values should i enter in the "Server Settings" menu?
serveradres: i tried my local IP number of my domoticsz instance that runs on a raspberryPi III (192.168.2.14)
protocol: i tried http
port: i tried 8080, ?
Map: ?
Username: ?
Password: ?
any advice?
Map: ?
Username: ?
Password: ?
any advice?
